Is it possible to remove just one MIDI mapping that was created with the MIDI learn function ? I do not want to use “Clean MIDI learn” and start from scratch.
It can be a bit fiddly, but it does work. From the manual:
Unlearning:
- In the “Instrument Control” screen, navigate through the parameter screen list until you get to the parameter you want to unlearn.
- In the parameter/controller area, slide with your fingernail from right to left. The tiny number, indicating the current CC assignment, should disappear or change. If the parameter is an engine-specific controlled engine, the number will disappear. If the parameter is a hardcoded MIDI-mapped parameter, the number will change.
I’ve not figured out a way to do it other than this.
