Resolved: SooperLooper: Loading Files freeze the entire Device
It's already been mentioned in the forum that loading
 audio files into the SooperLooper doesn't work.
Unfortunately, using this function causes the entire
device to freeze. A restart is necessary.
oram-2511.3
Kit 5.1
Best Regards
Andreas
The problem was my corrupt USB - Stick.
:wink:
Thanks Hans for the very good idea with capture workflow. That“s really nice to use.
Otherwise I donĀ“t know whats happen by freeze with ending the capture…
kind regards
Hello @aw-bs
I think it’s best to open an issue (using Webconf), and describe exactly what your are doing (all the steps) and what the results are.
Also it would help if you add an example of the audio file.
Your current description is a little limited for a developer to work with.
kind regards,
Hans.
