During a recent discussion somebody mentioned tests and API’s so could we start to build up a list of API calls and some details of the test that would exercise them?
1/ Restart GUI
GET call
parameter test=False ( not set returns current instance id hash)
returns hash of instance id . . .
Test.
checks for running GUI and records instance id
calls API
checks for running GUI and different hash.
2/ List Engines
Get Call
returns list of Engines Available
test compare with expected set.
3/ List Layers
GET Call
returns list of Layers Loaded
Test
Clean Machine ( No default snapshot’) returns 0 layers
4/ Add Layer
POST Call
parameter Engine
test
call List Layers (No default snapshot) assert 0 layers
call List Engines assert expected set
check test engine in set
call Add Layer
check test engine in list
5/ Delete Layer
POST Call
parameter Layer to delete
test
call {Add Layer test body (no TearDown) }
call Delete Layer layer 1
call List Layers
assert 0 layers
6/ Remove All Layers
GET Call
test
call Add Layer test2 Engine
assert Layer count
call Remove all Layers
call List Layers
assert 0 layers
He he - this doesn’t seem to have gone too far!!! What we do have now is CUIA which allows (almost?) complete control of the device via MIDI2CUIA interface. An OSC or other web based interface may be desirable but we can do the control side of things now. We do not have the feedback though, i.e. there is currently no indication to the testing device of the state of the device under test. I do not see CUIA performing such a task whereas OSC may provide a good interface. Other Restful API implementations may be preferred by some of our more web based (dare I say, younger?) contributors but an advantage to using OSC is that it is an interface that has an operational purpose so we may avoid overhead of implementing extra interfaces, i.e. if we implement OSC as an operational feature then we automatically gain it as a test feature.
It is unclear to me where we are with OSC implementation. It seems like it is on the back-burner but maybe we can warm it up again once Aruk is released.
