Hello to all,
first of all: Thank you for all the work you have already done. Zynthian is a great project and fulfills the open source ideas.
I am new to the forum and found the following problems:
I downloaded the latest version, put it on an SD-card and ist didn’t find any USB-device.
The only thing which was shown, was the internal USB hub:
root@zynthian:~# cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 4.19
S: Manufacturer=Linux 4.19.118-v7l+ dwc2_hsotg
S: Product=DWC OTG Controller
S: SerialNumber=fe980000.usb
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
On a fresh raspian it normaly looks like this:
root@pi1-ogsbb:~# cat /sys/kernel/debug/usb/devices
P: Vendor=1d6b ProdID=0002 Rev= 5.10
S: Manufacturer=Linux 5.10.17-v7l+ xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:01:00.0
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.10 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2109 ProdID=3431 Rev= 4.21
S: Product=USB2.0 Hub
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 4
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 5.10
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=5000 MxCh= 0
D: Ver= 3.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1
P: Vendor=1058 ProdID=2620 Rev=10.18
S: Manufacturer=Western Digital
S: Product=Elements 2620
S: SerialNumber=575833324431305035364C55
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=896mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I tried this several times with different cards and different RPi’s, the result was the same every time.
Nevertheless i tried the older version 2020-09-05 RC3 (which i tried in the last year and al work fine). This older version was running correctly.
Therefore i am wondering, what errors i made.
I tried the following:
Installing 2020-09-05 and than
apt update && apt-upgrade and voilà: the error occured.
After that i tried update the kernel, i found a 4.19 running and typed in:
apt install --reinstall raspberrypi-kernel
reboot
After that the RPi4 booted correctly and all usb devices are back.
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 14
T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=01 Dev#= 3 Spd=480 MxCh= 4
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=02 MxPS=64 #Cfgs= 1
P: Vendor=0424 ProdID=2524 Rev= 0.00
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 2mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=01 Driver=hub
I:* If#= 0 Alt= 1 #EPs= 1 Cls=09(hub ) Sub=00 Prot=02 Driver=hub
T: Bus=01 Lev=03 Prnt=03 Port=01 Cnt=01 Dev#= 5 Spd=1.5 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=050d ProdID=0102 Rev= 2.34
S: Manufacturer=Belkin Corporation
S: Product=Flip KVM
C:* #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=10ms
I:* If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=01 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 8 Ivl=16ms
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=2467 ProdID=2016 Rev= 0.32
S: Manufacturer=Nektar
S: Product=Impact LX25+
C:* #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 0 Cls=01(audio) Sub=01 Prot=00 Driver=snd-usb-audio
I:* If#= 1 Alt= 0 #EPs= 2 Cls=01(audio) Sub=03 Prot=00 Driver=snd-usb-audio
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
T: Bus=01 Lev=02 Prnt=02 Port=03 Cnt=03 Dev#= 6 Spd=12 MxCh= 0
P: Vendor=0d8c ProdID=0013 Rev= 1.00
S: Manufacturer=C-Media Electronics Inc.
S: Product=USB Audio Device
C:* #Ifs= 4 Cfg#= 1 Atr=80 MxPwr=100mA
I: If#= 1 Alt= 0 #EPs= 0 Cls=01(audio) Sub=02 Prot=00 Driver=snd-usb-audio
I:* If#= 1 Alt= 1 #EPs= 1 Cls=01(audio) Sub=02 Prot=00 Driver=snd-usb-audio
E: Ad=01(O) Atr=09(Isoc) MxPS= 200 Ivl=1ms
I: If#= 2 Alt= 0 #EPs= 0 Cls=01(audio) Sub=02 Prot=00 Driver=snd-usb-audio
I:* If#= 2 Alt= 1 #EPs= 1 Cls=01(audio) Sub=02 Prot=00 Driver=snd-usb-audio
E: Ad=82(I) Atr=0d(Isoc) MxPS= 100 Ivl=1ms
I:* If#= 3 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=87(I) Atr=03(Int.) MxPS= 4 Ivl=2ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
S: Manufacturer=Linux 5.10.17-v7l+ dwc2_hsotg
As you can see: Unfortunatly i have no original Zynthian running, i am using it
in a test environment with no RPi display and an external USB-Sound device.
What did not check: Which kernel is in the 2021-05-24 release.
Could it be a problem with an old kernel ?
Here are some more informations about the running system:
(taken from the web interface)
HARDWARE
Raspberry Pi 4 Model B Rev 1.4
Soundcard: [Generic USB device]
Display: [Generic HDMI Display]
Wiring: [DUMMIES]
GPIO Expander: [Not detected]
SOFTWARE
zyncoder: [stable (d852c8f) ]
zynthian-ui: [stable (b2f6a7c)
zynthian-sys: [stable (aefaf98)]
zynthian-ui: [stable (b2f6a7c)]
zynthian-data: [stable (f71259d)]
zynthian-webconf: [stable (153a020)]
SYSTEM
Raspbian GNU/Linux 10 (buster)
Build Date: 2020-09-05
Memory: 2% (166M/7875M)
SD Card: 35% (9.4G/29G)#
Temperature: 64.2ºC
__
Greets
Karl.T
