I can’t get this hardware working with ORAM:
RPI5
piFi Dac+ 2.0
After installation hw goes in a boot loop with ZYNTHIAN ERROR.
I’m close to giving up.
Any suggestion?
RPI5
piFi Dac+ 2.0
Any suggestion?
Have you tried setting Soundcard to Hifiberry Dac+ Light?
Yes, if I choose it
system stops the booting loop but touch screen stops working: for example I touch Admin and Admin menu voice is highlighted but does not call the admin submenu
The same for the other menu voices
I reflashed several times
here the log if could help:
Restarting UI in debug mode
Jun 24 13:06:01 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Jun 24 13:06:01 zynthian startx[1410]: X.Org X Server 1.21.1.7
Jun 24 13:06:01 zynthian startx[1410]: X Protocol Version 11, Revision 0
Jun 24 13:06:01 zynthian startx[1410]: Current Operating System: Linux zynthian 6.6.31+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64
Jun 24 13:06:01 zynthian startx[1410]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe smsc95xx.macaddr=2C:CF:67:14:E3:CA vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rootfstype=ext4 fsck.repair=yes rootwait console=tty3 logo.nologo quiet splash vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Jun 24 13:06:01 zynthian startx[1410]: xorg-server 2:21.1.7-3+rpt2+deb12u7 (https://www.debian.org/support)
Jun 24 13:06:01 zynthian startx[1410]: Current version of pixman: 0.42.2
Jun 24 13:06:01 zynthian startx[1410]: Before reporting problems, check http://wiki.x.org
Jun 24 13:06:01 zynthian startx[1410]: to make sure that you have the latest version.
Jun 24 13:06:01 zynthian startx[1410]: Markers: (--) probed, (**) from config file, (==) default setting,
Jun 24 13:06:01 zynthian startx[1410]: (++) from command line, (!!) notice, (II) informational,
Jun 24 13:06:01 zynthian startx[1410]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jun 24 13:06:01 zynthian startx[1410]: (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jun 24 13:06:01 2024
Jun 24 13:06:01 zynthian startx[1410]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Jun 24 13:06:01 zynthian startx[1410]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Jun 24 13:06:02 zynthian startx[1426]: /zynthian/config/img/fb_zynthian_boot.png is 800x480 PNG image, color type GRAY, 8 bit
Jun 24 13:06:02 zynthian startx[1426]: Zooming image by 100%...done
Jun 24 13:06:02 zynthian startx[1426]: Merging...didn't find evidence of prior run.
Jun 24 13:06:02 zynthian startx[1426]: done
Jun 24 13:06:02 zynthian startx[1426]: Building XImage...done
Jun 24 13:06:02 zynthian startx[1419]: ----------------------------------------------
Jun 24 13:06:02 zynthian startx[1419]: Linux Version: bookworm
Jun 24 13:06:02 zynthian startx[1419]: Kernel Version: 6.6.31+rpt-rpi-2712
Jun 24 13:06:02 zynthian startx[1419]: ZynthianOS Version: 2405
Jun 24 13:06:02 zynthian startx[1419]: Virtualization: none
Jun 24 13:06:02 zynthian startx[1419]: Hardware Architecture: aarch64
Jun 24 13:06:02 zynthian startx[1419]: Hardware Model: Raspberry Pi 5 Model B Rev 1.0
Jun 24 13:06:02 zynthian startx[1449]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Jun 24 13:06:02 zynthian startx[1449]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->setup_zynswitch(1, 17, ...): Can't request line events from RPI GPIO
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->setup_zynswitch(2, 17, ...): Can't request line events from RPI GPIO
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->setup_zynswitch(3, 17, ...): Can't request line events from RPI GPIO
Jun 24 13:06:03 zynthian startx[1449]: ZynCore: Setting-up 4 x Zynswitches...
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->setup_zyncoder(0, 17, 17): Can't configure zyncoder on a single pin!
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->setup_zyncoder(1, 17, 17): Can't configure zyncoder on a single pin!
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->setup_zyncoder(2, 17, 17): Can't configure zyncoder on a single pin!
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->setup_zyncoder(3, 17, 17): Can't configure zyncoder on a single pin!
Jun 24 13:06:03 zynthian startx[1449]: ZynCore: Setting-up 8 x Zynpots (zyncoders)...
Jun 24 13:06:03 zynthian startx[1449]: ZynCore->gpiod_start_callbacks: Callback thread created successfully
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1719211670.16356
Jun 24 13:06:03 zynthian startx[1449]: Started libzynaudioplayer using libsndfile-1.2.0
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_main.<module>: STARTING ZYNTHIAN-UI ...
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_state_manager.__init__: Creating state manager
Jun 24 13:06:03 zynthian startx[1449]: Started libzynmixer
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_chain_manager.__init__: Creating chain manager
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_engine_alsa_mixer.get_controllers_dict: MIXER CTRL LIST: ['Digital_0', 'Digital_1']
Jun 24 13:06:03 zynthian startx[1449]: Started libzynseq
Jun 24 13:06:03 zynthian startx[1449]: Started libzynsmf
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_state_manager.start: Opened temperature sensor '/sys/class/hwmon/hwmon0/temp1_input'
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_state_manager.start: Opened undervoltage sensor '/sys/class/hwmon/hwmon3/in0_lcrit_alarm'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_autoconnect.init: Initializing 24 slots for MIDI devices
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 MIDI 2'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 IN 2'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_midimix' for devices with ID 'MIDI Mix IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_mpk_mini_mk3' for devices with ID 'MPK mini 3 IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_duopiano' for devices with ID 'GENERAL IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_korg_nanokontrol2' for devices with ID 'nanoKONTROL2 IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchkey_mini_mk3' for devices with ID 'Launchkey Mini MK3 IN 2'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini' for devices with ID 'Launchpad Mini IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini_mk3' for devices with ID 'Launchpad Mini MK3 IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk2' for devices with ID 'Launchpad Pro IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk3' for devices with ID 'Launchpad Pro MK3 IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_x' for devices with ID 'Launchpad X IN 1'
Jun 24 13:06:03 zynthian startx[1449]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_riband' for devices with ID 'riband Bluetooth'
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 0: ttymidi:MIDI_in
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 1: ZynMaster:midi_out
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 0: ttymidi:MIDI_out
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 1: ZynMaster:midi_in
Jun 24 13:06:03 zynthian startx[1449]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 0 => midi_chan=None, mixer_chan=16, zmop_index=None
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:selector_events.__init__: Using selector: EpollSelector
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynthian_gui_patterneditor.get_custom_keymap: MIDI channel 0 has not synth processors.
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui_brightness_config.get_backlight_sysctrl_fpath: Display brightness control file: /sys/class/backlight/4-0045/brightness
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynthian_gui_brightness_config.init_ctrls: Setting display brightness to 255.
Jun 24 13:06:04 zynthian startx[1449]: ZynCore->setup_behaviour_zyncoder(0, ...): Invalid index!
Jun 24 13:06:04 zynthian startx[1449]: ZynCore->setup_behaviour_zyncoder(1, ...): Invalid index!
Jun 24 13:06:04 zynthian startx[1449]: ZynCore->setup_behaviour_zyncoder(2, ...): Invalid index!
Jun 24 13:06:04 zynthian startx[1449]: ZynCore->setup_behaviour_zyncoder(3, ...): Invalid index!
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynthian_gui.zynswitches_init: INIT 0 ZYNSWITCHES ...
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynthian_gui.zynswitches_midi_setup: CUSTOM I/O SETUP...
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui.close_screen: SCREEN HISTORY => []
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'loading' => Back to 'audio_mixer'
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynthian_state_manager.load_snapshot: Loading snapshot '/zynthian/zynthian-my-data/snapshots/last_state.zss' ...
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynthian_processor.get_bank_list: Loaded 1 banks
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Jun 24 13:06:04 zynthian startx[1449]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Jun 24 13:06:04 zynthian startx[1449]: INFO:zynseq.restore_riff_data: Restoring RIFF data...
How do you know that touchscreen behaviour changes? Surely during the restart cycling you have no touchscreen control?
There has been a regression over the weekend that has effected some touch control. I expect @jofemodo will testing that today. It may be relevant to your issue.
you are right
with new update touch screen is finally working ![]()
I reinstalled my HifiDAC NXEZ that works using [JustBoom DAC] settings
piFi Dac+ 2.0 card is silent if you use Hifiberry Dac+ Light ![]()
anyway, I am happy that system works
counter-order:
after latest update touch screen admin> rebootZ not working
switch off / switch on and system does not boot once more (fifth time)
I’ll close the HW in a drawer for a month
Touchscreen reboot from admin menu works for me.
I have experienced this with my V3 with RPi3. I find it needs power to be reset a couple of times before it boots. I have not figured out why but wondered if it is a similar issue to you are having with RPi5. They are very different devices but it is plausible that there is a common cause. Have you tried repowering a few times?
