Hi all,
here is a simple manual/recipe for some optimization of your Zynthian.
Please note: THIS IS BETA! DON’T USE IF YOU DON’T KNOW WHAT YOU ARE DOING!
What we are doing today is to try to divide processes into nrt (non-realtime) and rt (realtime). Why should we do this?
The standard preemptive Linux kernel is really good for audio processing - jack2 (our audio server) works very well also on high loaded systems. But on top we can say: I want to use 2 or 3 of my cores only for audio and the rest should work for the GUI, etc.
A very nice manual describes this and from there I also noticed there is a good tool for making everything easier: https://github.com/OpenEneaLinux/rt-tools.
Ok, let’s go: We want to device our 4 core of a Raspi-2/-3 (every step is in a script in https://github.com/dcoredump/zynthian-recipe/recipre/rt-tools.sh):
- Add the following to
/boot/cmdline.txt
:cgroup_enable=cpuset isolcpus=1,2,3
. The line shoud look like this:
dwc_otg.lpm_enable=0 console=tty1 elevator=noop root=/dev/mmcblk0p2 rootfstype=ext4 fsck.repair=yes cgroup_enable=cpuset isolcpus=1,2,3 rootwait
We are telling the kernel only to use CPU0 (ans not CPU1,2,3). Also we enable cgroup - a feature for advising processes to a CPU-set. - Now clone, build and install
https://github.com/OpenEneaLinux/rt-tools.git
- Reboot
If we now look at our used CPUs (e.g. with htop
) there should only CPU0 be used. This CPU is for our nrt-processes. The other 3 CPUs are for the rt-processes. Now we can use partrt
for creating and advising processes to the CPUs.
- First calculate a bitmask. The mask for CPU2,3,4 is
0xe
(for CPU2,3:0xc
). - Create a CPU-set for rt:
partrt create 0xe
- Now you can move a process (you have to know the PID) to the rt-CPU-set:
partrt move <PID> rt
or you can start a new process directly on the rt-CPU-set:partrt run -f 99 rt /usr/local/bin/jackd -R -P99 -d alsa -dhw:0 -r48000 -p256 -n2 -Xraw
(here I have also used the option-f99
as FIFO schedular with priority 99).
I tuned my Zynthian for using 2 CPUs for rt and changed the systemd-scripts so they start jack2
and mod-host
on the rt-CPU-set.
Note: Every new started process (compiler, …) is located per default on the nrt-CPU-set and cannot advise threads anymore to more CPUs than located in nrt (or rt)! So: Compiling on 4 CPUs is not doable anymore!
And a nice trick for getting some more CPU cycles for other things:
sysctl vm.dirty_writeback_centisecs=1500
This avoids too fast writebacks to the SD card (if I had understand right). This can simply be added add the end of /etc/sysctl.conf
Regards, Holger
