You have to open a midi router in the computer where the device is connected (like MidiOx in Windows) and connect that midi device to the RTP-Midi port you want to use in Zynthian.
ok thank you, iâve got it working now
the other device is my phone, and it took me a short while to find an iOS app that would initiate the midi session - but then i found Midi Network app
so first try - with midi generated in Fugue Machine on iOS, played through ZynAddSubFX â Collection â Simple Chimes, with a little bit of extra resonance
Hi @zynthianers!
RTP-MIDI integration is complete now. You can enable/disable RTP-MIDI from the UIâs admin menu and also from the webconf. When enabled, the input/output ports will be autoconnected, so no need for patchage.
The only thing i miss is the possibility of being an âinitiatorâ, so we can connect our zynthian to tablets and other âlistenersâ. I mean, i would like to use my IPad as sequencer.
Just update and enjoy!!
I get
Jan 30 01:18:44 zynthian startx[495]: Failed to start jackrtpmidid.service: Unit jackrtpmidid.service not found.
Jan 30 01:18:44 zynthian startx[495]: ERROR:zynthian_gui_admin: Command 'systemctl start jackrtpmidid' returned non-zero exit status 5.
I just updated my Zynthian, and I tried to start RTP-MIDI from the UI, but I get:
Jan 30 02:22:57 zynthian startx[432]: ERROR:zynthian_gui_admin: Command 'systemctl start jackrtpmidid' returned non-zero exit status 1.
Jan 30 02:25:51 zynthian startx[432]: Failed to start jackrtpmidid.service: Unit jackrtpmidid.service has a bad unit file setting.
Jan 30 02:25:51 zynthian startx[432]: See system logs and 'systemctl status jackrtpmidid.service' for details.
Jan 30 02:25:51 zynthian startx[432]: ERROR:zynthian_gui_admin: Command 'systemctl start jackrtpmidid' returned non-zero exit status 1.
Jan 30 02:25:53 zynthian startx[432]: Failed to start jackrtpmidid.service: Unit jackrtpmidid.service has a bad unit file setting.
Jan 30 02:25:53 zynthian startx[432]: See system logs and 'systemctl status jackrtpmidid.service' for details.
Jan 30 02:25:53 zynthian startx[432]: ERROR:zynthian_gui_admin: Command 'systemctl start jackrtpmidid' returned non-zero exit status 1.
Jan 30 02:26:11 zynthian startx[432]: Failed to start jackrtpmidid.service: Unit jackrtpmidid.service has a bad unit file setting.
Jan 30 02:26:11 zynthian startx[432]: See system logs and 'systemctl status jackrtpmidid.service' for details.
Jan 30 02:26:11 zynthian startx[432]: ERROR:zynthian_gui_admin: Command 'systemctl start jackrtpmidid' returned non-zero exit status 1.
jackrtpmidid.service is in /etc/systemd on github , shouldnât it be in /etc/systemd/system ?
Well at least you can ssh and manually run jackrtpmidid. And it will work.
Oh, I wonder if I have a jackrtpmidid bin kicking around which is stalling the script.
at my Zynthian it is placed in /etc/systemd/system. But it didnât works, if you start automaticly via âsystemctl enable jackrtpmididâ. The path to jack_wait couldnât be resolved so the path should be absolutly â/usr/local/bin/jack_wait -wâ. Then it starts at boot time.
Greetings
Roman
Sorry guys! It should be fixed now. Simply update again âŠ
Sorry, I furtherwise have a problem with connention ZynMidiRouter:main_out to jackrtpmidid:rtpmidi_in. I got feedback from midi notes and others.
Roman
Please, forget connecting by hand. Simply update your zynthian and enable RTP-MIDI from the admin or webconf.
The connection will be established each time I create a new layer. No connection made by hand. The blue m is allways on until I removed this connection.
Greetings Roman
Hi Roman.
Is it giving feedback (stuck notes for instance) now? To solve this i had to remove the ZynthianMidiRouter out connection to JackRtpMidi, but this was before this final integration made today. I donât have access to my Zynthian at this moment to try it.
I updated and rebooted my Zynthian, aaand⊠it works!
Thanks, @jofemodo!
Uh oh, I think I hear @wyleuâs heavy footsteps behind meâŠ
This is me controlling Helm, Noize Mak3r, and a TR909 soundfont from my laptop via LMMS. Wirelessly!
now, after updating, it is perfect working. Thank you very much to Jose and Benoit.
Greetings
Roman
And source code of the daemon is now on my Github, if somebody wants to play with it
Just one thing : the compiled version on the Github is still V0.3, but the source code is 0.4 (V0.3 is the one currently in the Zynthian too)
I will put the V0.4 tomorrow on the Github, along with the Netbeans project I use to compile it.
Benoit
Hi Benoit!
This is fantastic!! Iâm pretty sure you will find some collaborator âŠ
BTW, you forgot the LICENSE.txt
Hi José,
donât thank me, the pleasure is for me to know that my work is now a little part of this great project called Zynthian
I will add the missing files (like license.txt) at the same time I will put the Netbeans project file.
I need to do some cleanups in the Github like moving the binary file somewhere else, I will do this as soon as I have time
Benoit
Hi all,
I have two issues with RTP-MIDI on my Zynthian.
When I restart my Zynthian, RTP-MIDI deactivates systematicially. After the reboot, if I go in Admin menu, RTP-MIDI option is always unchecked. And RTP-MIDI is really deactivated (not only a display bug), since I have to enable it again if I want to connect a RTP-MIDI remote device to the Zynthian
If I activate RTP-MIDI using the webserver (MIDI Options), the checkbox remains checked after the reboot, but the checkbox in Admin menu is unchecked.
Does somebody else has the same problems ?
Benoit
