RTP-MIDI on zynthian
Hey Baggypants,
it’s normal that you can’t see it on your iPad. Both the iPad and the Zynthian (with rtpmidid) are session listeners. You need a session initiator in front of the daemon to invite it and negotiate the session.
If you have a Mac, you can use the Network MIDI applet in MIDI/Audio configuration (in System Tools) to create such a session
If you have a PC, you can install rtpMIDI driver from Tobias Erichsen. It has exactly the same user interface than the Mac driver by the way.
For details about the configuration, I recommend you to take a look here, this is the document I wrote for KissBox a few years ago to explain the use of RTP-MIDI https://kiss-box.nl/downloads-archive/integration-guide/
Note that rtpmidid daemon is able to become a session initiator (my RTP-MIDI source code contains everything for that), but it would need to be modified to accept arguments (becoming a session initiator requires to know the IP address and the UDP port to invite on the remote device). I did not implement this yet, because I am not sure it would be easy to enter an IP address and a port number on the Zynthian GUI.
If you think that this would be feasible, then I can implement command line parameters to handle this mode. Give me your feeling about this.
Benoit
Well, now you have the advantage over me! I have neither Windows nor MacOS. :slightly_smiling_face:
Hi ,
please take a look at this side : RTP-MIDI.
You will find also the raveloxmidi as discussed at the beginning of this thread.
Greetings
Roman
Hey baggypants,
I will not make the classical joke “you don’t know what you miss” :wink:
I think that the rtpmidid should solve your issue (and by the way, from what I can see, you can follow explanations given in the PDF to understand what you have to do on the computer side)
As I said to Roman, if you have problems to establish a session between the Zynthian and a session initiator, use -verbosertp switch on the command line of rtpmidid, it will show you the session control
Benoit
Seems to work good on a wired connection. Haven’t got it working on wireless as patchage crashes before I can configure it.
I suspect the remote x server is hogging to much bandwidth, and my keyboard sends midi clock as well.
Hi @zynthianers!
I found this:
:wink:
And the Avahi (aka “Bonjour”) should allow to detect listeners and select from a list (or autoconnect it) without having to write the IP/Port … or am i wrong?
Yes, you are right. mDNS advertize the IP and port of a remote device, so once you know them, you can start a session by using the parameters they have transmitted.
However, take care of one thing : not all RTP-MIDI devices implement Bonjour/mDNS. So, in theory, it is better to offer both options :
  • select a mDNS device from a list (where you can find the names of the device advertising using mDNS)
  • enter manually IP and port to allow connection to device not implementing mDNS
Benoit
Currently, entering an IP from zynthian UI is not an option, so, when working as a RTPMIDI master. only Bonjour/mDNS-enabled devices would be initiated from Zynthian,
Of course, zynthian itself, as a listener, is already notifying RTPMIDI by Avahi (aka mDNS/Bonjour) :wink:
Simply update software and reboot …
I just tried via wifi and in my rpi4+Hifiberry DAC+ ADC barebone Zynthian it is flawless. I made sure to have Mobaxterm and ssh connections alive to try to “hog” the wifi band but till now with no issues.
Nice job
Hi José,
do you mean that RTP-MIDI daemon is now included in the last software ?
If so, I have a problem : I have made a software update (from Admin menu) and a reboot, but I see no RTP-MIDI activity coming from the Zynthian (and I can not connect to it anyway from a RTP-MIDI driver)
I am sure that update was done well, since I see now a MIXER entry on the Layer page (and this entry was not there just before the update)
Is there a way to check if the daemon has been included correctly during the update ?
Benoit
Hi Jose,
same to me. I’ve updated and seen that there was included a script jack???rtpmidi.sh, but I can’t explore anything in patchage?
Greeitngs
Roman
UPDATE:
I copied the jackrtpmidi by hand in the /usr/local/bin directory and did the chmod.
But the start of the services failed.
I think its just in prep for adding it. The recipe to install it is there.
you can ssh into it and run jackrtpmidid &
Then run patchage and hook it up to test it out.
Next would be to have the ui to turn it on and off. and add/remove it from the graph.
Hi, normaly I do this job via systemctl.
I just tried setting this up for first time and found that modui shows afar more midid ports than i had hoped for :smiley: :smiley: :smiley:
Try to guess who made the announcement… :innocent:
I have no idea … :thinking:
ok so i’ve updated, installed via the recipe & run “jackrtpmidid &” - i can see there’s a jackrtpmidid element in the patchage UI with “rtpmidi_in” and “rtpmidi_out” that are not connected to anything - i guess that means i need to “hook it up” manually, but i don’t know what to connect it to
what do i need to “hook it up” to, please?
You should have a Zyn midi router in patchage. Connect it there
OK like this, yes? (outlined in yellow box)
but what about the input? i have a separate device on the same network that’s generating midi - do i need to connect that to rtpmidi_in? if so, how?
