Saving snapshots in Oram
I’m slowly trying to rewrite collection of my old snapshots to new Oram. And one of them is for my live cover band usage - with Program changes ZS3 subsnapshots. And there is something strange happening when I trying to save it “as new snapshot” or simply save after some tweaking or changes. All zs3 are “empty”. Im attaching two snapshots one before and one after saving.
Maybe I’m doing something wrong, maybe there some changes in the way of creating subsnapshots (For example I’m still do not know what is “state zero” zs3).
004-before.zss (188.8 KB)
004-after.zss (43.5 KB)
And there is a significant size difference between them.
Adam
Hi @ejdzi !
I just copied your “before” snapshot to my zynthian, played a little bit, tested the ZS3s, etc. Then i saved as a new snapshot and i got the same result than you. Indeed, if you overwrite the original snapshot you also will get a “truncated” snapshot. Take care!
I will solve it ASAP!
Hi @ejdzi !!
Is this a legacy snapshot that you imported to Oram or did you create it from scratch?
Completely from scratch.
First I set chains on different channels. Then on the first channel I saved zs3’s changing presets. In the last two zs3 changes was made also on other channels. Then snapshot is saved. And everything was ok. And then another save and this result.
Hi @ejdzi !
I found and fixed the issue. Please, update and test.
Thanx. As always wonderful. All is working as expected now. :grinning:
