Sorry, I assume this may be an absolute noob question but how can I use one dedicated FX chain (reverb, delay) for several instruments (instrument chains)? Like a send fx buss in my DAW for example?
Thanks for help
Thanks for help
I wish I could point to a more complete tutorial, but the closest I know of is this in the built in help:
Hmmmm, I don’t know if the full link actually made it above, what I’m going for is:
help dot zynthian dot org slash chain_config dot html
Hi @Lumm,
I have achieved, quite successfully, this desirable behaviour that saves considerable CPU resources, instancing new chains, from main view, as mix-busses equipped with the required FX processors.
Then, you need to send to the FX bus chains - normally visible in the mixer view on the right side, aside the main mixbus - the audio output (in the cascaded chain options view) of the instruments or audio sources that you want to address to those effects. Remember to also send the signal to the main mixbus, for the untreated audio component to be audible.
Be aware that, for the moment and AFAIK, there is no per-chain return ratio control, so for the moment the amount of FX treatment depends globally on the fader level of the FX-send bus chains (unless something has changed in the meantime and it slipped off my guard).
Best regards ![]()
Effects send and return is now fully implemented in vangelis, removing the odd workflows needed before.
So we now have a very familiar (to sound engineers) effects send and return mechanism. This is just like a standard mixing desk, except the quantity of sends and returns is dynamic. By default the mixbus chains appear pinned to the right of the display but you may pin / unpin any chain by moving (or dragging) left / right.
Didn’t realise it was already there and fully implemented with sends-returns. Excellent! ![]()
Thanks so much for the timely help. Maybe I was searching wrong (wrong key words) or I am still a little to ill at the moment (another late Corona variant hit me) which makes my brain works half power.
The mixbus with fx send feature is definitely a crucial feature for having fun with Zynthian. And of course, as said, it saves much computing power (one fx chain for many instruments). Again thanks to the amazing developers.
You can also use this for creating groups, monitor mixes, etc. because it is a chain so it’s outputs can be routed as desired. The old method of routing chains to other chains remains available. I am glad others like this and appreciate it as I do.
