Sequencer trigger device not saved
It seems that the trigger device is not (reliably) saved in the sequencer. I have now saved 3 snapshots and set up one of my MIDI devices (Products - Hotone Audio) as a trigger to start a Zynpad. After restarting Zynthian and loading the snapshot, it seems as if a device is randomly entered as a trigger. There exists 3 midi devices in my setup, all connected via USB. After I manually correct the device, everything works as expected. Can anyone confirm this?
The background is that I can start/stop the sequencer with my foot while I play the piano. I am using Zynthian V5.1 with Pi5 8GB and the latest ORAM stable release.
Could you report it…?
You have to zip up snapshot files to make then acceptable to git’s tracker?
Thanks for the hint. I reported an issue just now in git: Bug: Sequencer trigger device not saved/loaded correctly · Issue #1250 · zynthian/zynthian-issue-tracking · GitHub.
Thanx. A nicely presented bug report.
