After updating my system I tried to rearrange my presets.
Pianoteq works, FluidSynth works, but SetBFree gives no sound.
I see, that the MidiIcon is flickering, but no sound.
What can I do?
to reproduce:
Layers/New Synth Layer
Engine/setBfree
MidiCh#1
Upper
Sine
AWSOP
→ no Sound
Exception in Tkinter callback
File "/usr/lib/python3.7/tkinter/__init__.py", line 1705, in __call__
return self.func(*args)
File "./zynthian_gui.py", line 1822, in cb_keybinding
zyngui.callable_ui_action(action)
File "./zynthian_gui.py", line 803, in callable_ui_action
self.zynswitch_short(3)
File "./zynthian_gui.py", line 1132, in zynswitch_short
self.screens[self.active_screen].switch_select('S')
File "/home/pi/zynthian-ui/zyngui/zynthian_gui_selector.py", line 251, in switch_select
self.click_listbox(None, t)
File "/home/pi/zynthian-ui/zyngui/zynthian_gui_selector.py", line 247, in click_listbox
self.select_action(self.index, t)
File "/home/pi/zynthian-ui/zyngui/zynthian_gui_bank.py", line 69, in select_action
if self.zyngui.curlayer.set_bank(i):
File "/home/pi/zynthian-ui/zyngine/zynthian_layer.py", line 150, in set_bank
return self.engine.set_bank(self, self.bank_info)
File "/home/pi/zynthian-ui/zyngine/zynthian_engine_setbfree.py", line 301, in set_bank
self.generate_config_file(midi_chans)
File "/home/pi/zynthian-ui/zyngine/zynthian_engine_setbfree.py", line 215, in generate_config_file
cfg_data = cfg_data.replace('#OSC.TUNING#', str(self.zyngui.fine_tuning_freq))
AttributeError: 'zynthian_gui' object has no attribute 'fine_tuning_freq'
Mar 13 12:31:43 zynthian startx[6728]: File “/home/pi/zynthian-ui/zyngine/zynthian_engine_setbfree.py”, line 215, in generate_config_file
Mar 13 12:31:43 zynthian startx[6728]: cfg_data = cfg_data.replace(‘#OSC.TUNING#’, str(self.zyngui.fine_tuning_freq))
Mar 13 12:31:43 zynthian startx[6728]: AttributeError: ‘zynthian_gui’ object has no attribute ‘fine_tuning_freq’
hello friends i greet you together. i have a question please can you buy a synth for zynthian where i can edit the tones and save it because i am zynthian all synth are blocked you cannot save any sound. is it possible to buy a synth?
