Yes Wyleu, sorry, I explained myself wrong … The problem of the pedal that didn’t work is solved … it was on a wrong midi channel … The problem of the Grand Piano SFZ is another … If I play many chords and therefore I have to move the pedal a lot, when I release and push the pedal at the same time as the chord change, the sound stops even if my hands are holding the keys pressed … I had put an audio file in another post, now I’ll put it back here. Thank you
