I haven’t used my Zynthian k3-pro in a while. So I ran software update on the Zynthian but it looked like many things failed. Next I burnt a new image onto a new SD card (latest image from the wiki.
Zynthian immediately started but gave me the red ERROR IP: message. I logged in, nonetheless from the webconf page and updated my wireless network. And I ran software update. Everything seemed to go just fine.
Now my Z starts and gives me the red ERROR message along with the IP address 192.168.1.41 I use for the webconf page.
When I reboot I continue to get the error message. Basically, this is all I did
- Connect your Zynthian Box to your router/switch using an Ethernet RJ45 cable. Alternately, you can configure the WIFI connection using the Webconf tool.
- Click update software from the UI’s Admin Menu
- Click restart UI (or reboot) from the UI’s Admin Menu
while connected through ethernet to an extender that’s wired to my router.
If someone could set me straight I’d be very grateful!
Thanks in advance,
Mark
… I can also ssh into root@ip_num
and
aplay -L suggests that Zynthian isn’t seeing my Hifiberry DAC+ADC Pro, even though the web interface sees it?
root@zynthian:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Headphones
bcm2835 Headphones, bcm2835 Headphones
Default Audio Device
sysdefault:CARD=Headphones
dmix:CARD=Headphones,DEV=0
Direct sample mixing device
dsnoop:CARD=Headphones,DEV=0
Direct sample snooping device
hw:CARD=Headphones,DEV=0
Direct hardware device without any conversions
plughw:CARD=Headphones,DEV=0
Hardware device with all software conversions
