Hi All,
It’s not a big deal but it would be a nice to have…
Is there a way to boot Zynthian without all these codelines flying by
before showing the actual bootscreen…
Hi All,
This is the default for V4 & V5, but boot log is enabled for “DIY” kits to help with diagnostics.
You can change it easily.
I unterstand the use for it. But where can I change this. In the webUi?
Found IT !!!
Unfortunately the changed setting in the Cmdline.txt are overwriten to original coldboot.
So the silent boot is not permanent. I see the same thning happening when changing the bootscreen/picture
You have to do this modifications from the webconf, @Rotil66 .
Look into the hardware->options submenu.
It’s commented in the wiki:
https://wiki.zynthian.org/index.php/Web_Configuration_User_Guide
=>Section 4.5
Ok thanks, will take a look
Is there any info on how to use this custom config/boot option.
Just entering the command is not working
What do you enter? What is the result in the config file?
To get a silent boot I have to change
console=tt1 to console=tt3 in the cmdline.txt
As far as I understand for the info on the web.
This works but is not lasting after a coldboot.
Also I would like to have my own startup picture. I can change it but this is also not lasting after a coldboot.
the last thing which obviously isn’t that easy, is that i can’t get a good working display.
At the moment I have a 5" 1024x600 screen.
But the touchoverlay is off and probably on 800*600.
sorry for the many questions
Any tip on how I can do these things??
thanks!!!
If it is an HDMI screen, then you can put into the bootloader configuration HDMI_DELAY=8 or a different number than 8, which you may have to try out.
This example begins the output of the HDMI video signal 8 seconds after the start/restart of the Pi, which then is realtime and not delayed.
See documentation here https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#HDMI_DELAY
And how to mod the eeprom bootloader config:
Does this "fake numa trick" work on Zynthian? - #5 by fussl
thanks, but it’s a DSI display
so I assume this doesn’t apply to this screen.
