Oh no
Is this a recurring theme?
Not my best, keep getting distracted by roommates Cat. Sooooo cute
On octave wars in dexed
Loving the acoustic foley but be aware that you can record directly within the Zynthian using the Audio Recorder then access the files (WAV or convert to OGG) via webconf Library->Captures.
lol, yeah. I figured that feature is there, but it’s tricky to use since I’ve no knobs or switches, and the 5 inch touchscreen in using on the second zynthian is not a functional control surface (upside down and flipped, and suuuuper sensitive). Is there a list of keyboard shortcuts? That’s what I’ve had to use to select the instruments
Zynthian UI Users Guide - ZynthianWiki
Indeed it is worth reading the user guide as it has a lot of info guiding… use
Makes sense it would be there. I’ve been in it a few times, but reading the entirety of dry technical info can be difficult with unmedicated ADD. Been meaning to take another look at it, but thought maybe there’d be an easy picture or list. But thanks @riban, at least now I know it’s definitely in the user guide. Not exactly a guarantee with these sort of things
Such a cool enclosure! Great work.
