Hi @Zynthianers!
I’ve uplaoded some changes to the repository. The changes include some bugfixes and improvements. The most important:
- New “Preset Manager” tab in the Webconf tool. (Thanks @mheidt!! )
- Fix the “WIFI network list” when adding a new network. It still don’t show all networks, but it works.
- Really fix the problem with WLAN interfaces numbering
- Fix OSC controllers in ZynAddSubFX when layer number and channel number are not the same.
- More reliable method of getting the IP in the “Network Info” from Admin Menu (Thanks @vbretsch!)
- etc.
For getting the changes, you only have to connect your Zynthian to your local network and use the “Update Software” option from the Admin Menu.
If you prefer the command line:
# /zynthian/zynthian-sys/scripts/update_zynthian.sh
