gigedit crashes when I open the file…but why does linuxsample doesn’t “say” anything?
root@zynthian:/zynthian/zynthian-my-data/soundfonts/gig# ls
cp70.gig
INFO:root:Connecting with LinuxSampler Server…
DEBUG:root:ZCTRL ‘Channel’: 0 (0 -> 16), None, None
INFO:root:Short Switch 3
DEBUG:root:CTRL Decay [ms] => ms
DEBUG:root:CTRL Dry Level [dB] => dB
DEBUG:root:CTRL Wet Level [dB] => dB
DEBUG:root:CTRL Comb Filters => None
DEBUG:root:CTRL Allpass Filters => None
DEBUG:root:CTRL Bandpass Filter => None
DEBUG:root:CTRL Enhanced Stereo => None
DEBUG:root:CTRL Reverb Type => None
DEBUG:root:CTRL Frequency [Hz] => Hz
DEBUG:root:CTRL L/R Phase Shift [deg] => deg
DEBUG:root:CTRL Depth [%] => %
DEBUG:root:CTRL Delay [ms] => ms
DEBUG:root:CTRL Contour [Hz] => Hz
DEBUG:root:BANK LIST =>
[(’/zynthian/zynthian-ui/data/soundfonts/sfz/Bass’, 0, ‘SFZ/Bass’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Brass’, 1, ‘SFZ/Brass’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Drum Machines’, 2, ‘SFZ/Drum Machines’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Drums’, 3, ‘SFZ/Drums’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Ethnic’, 4, ‘SFZ/Ethnic’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Guitars’, 5, ‘SFZ/Guitars’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Organs’, 6, ‘SFZ/Organs’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Other’, 7, ‘SFZ/Other’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Percussion’, 8, ‘SFZ/Percussion’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Pianos’, 9, ‘SFZ/Pianos’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Strings’, 10, ‘SFZ/Strings’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Synths’, 11, ‘SFZ/Synths’, ‘SFZ’), (’/zynthian/zynthian-ui/data/soundfonts/sfz/Woodwinds’, 12, ‘SFZ/Woodwinds’, ‘SFZ’)]
DEBUG:root:BANK INDEX => 0
DEBUG:root:ZCTRL ‘Bank’: 0 (0 -> 13), None, None
