I just got my zynthian v5 today, got the latest image, put it on sdcard after checking md5sum, but at boot, I only see a console, the wrong way around from what seems to be the normal perspactive to look at the device, saying kernel panic after quite a bit of error output.
From the messages I dont get an idea on what could be wrong.
Is it a hardware / assembly problem? Or something with the software?
Thanks a lot!
I tried another SD card and that worked.
For debugging reasons - and to understand if the issue was caused by a generally broken card or maybe the size - I recreated the first card again, too, and checked, and that worked, too.
So i must have had some strange problem with the image, but in the end the bot cards, a 32 and a 64G worked fine.
