I’ve got a custom wm8731 board that I’ve designed by following the Wolfson reference design. It just adds some extra pins for testing different line in preamp stage. It use a 12MHz crystal as the audioinjector, so that is the setting I’ve selected in the webconf.
Aplay -l (and arecord -l) shows the audioinjectorpi device.
card 2: audioinjectorpi [audioinjector-pi-soundcard], device 0: AudioInjector audio wm8731-hifi-0 [AudioInjector audio wm8731-hifi-0]
But, as is, jackd isn’t loaded at startup (jack_wait). I have to stop zynthian and jack2 service, and then start jack2 service to get it up and running.
Ok, let’s solve this problem later because even with jackd running, zynthian won’t start.
UI log tells me:
Jun 01 13:14:36 zynthian startx[1171]: Cannot read socket fd = 7 err = Success Jun 01 13:14:36 zynthian startx[1171]: CheckRes error Jun 01 13:14:36 zynthian startx[1171]: JackSocketClientChannel read fail Jun 01 13:14:36 zynthian startx[1171]: Cannot open jackpeak client Jun 01 13:14:36 zynthian startx[1171]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock Jun 01 13:14:36 zynthian startx[1171]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock Jun 01 13:14:36 zynthian startx[1171]: libjackpeak failed to start jack client: 33
and
jack_lsp -c outputs:
Cannot read socket fd = 5 err = Success
CheckRes error
Cannot open lsp client
Error: cannot connect to JACK, jack_client_open() failed, status = 0x21
Ok, let’s stop jack2 and perform a basic aplay test:
aplay -D hw:2 /usr/share/sounds/alsa/Noise.wav
Playing WAVE ‘/usr/share/sounds/alsa/Noise.wav’ : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
aplay: set_params:1349: Channels count non available
Specifying -c2 or -c1 in aplay parameter doesn’t change anything: same error message.
Any advice for investigating that further ?
