Hi
Is there a way to load files in SooperLooper loops (aside in windows mode) or is there future features (working with zs3) ?
Hi
Zynthian’s implementation of SooperLooper is supposed to allow saving of presets but there is a missing element at the moment. It can be done from the GUI but that requires running up slgui and saving the session to /zynthian/zynthian-my-data/presets/sooperlooper (which does not exist by default). I’m not sure how the user preset feature got broken. It needs fixing. (A bug report would be a start!)
These presets are native SooperLoop sessions which include a slsess session file and associated wav files. So it should be possible to implement a method to import / export sessions, e.g. using webconf’s preset interface. This will only happen if someone raises a feature request and then someone finds the time and enthusiasm to implement it!
In short, there are not plans but there could be. ![]()
Ok Thanks
May be i’ll look when time…
Hmm does this mean currently SuperLooper sessions are entirely ephemeral and anything in them is gone forever when one loads another snapshot?
there is a way:
When in the sooperlooper screen press “CTRL/Preset”
Bold press Enc4
Save as new!
It does not save in the snap, but when you reload your snap you can go to sooperlooper->Preset and then choose the one you just saved.
Maybe there are other ways, but this i just tested!
If you saved the snapshots after saving the preset, the preset should be restored with the snapshots.
