SooperLooper - Loop 2 disconnected - someone else?
Hi
Strange SooperLooper behaviour !
The second Loop does not work, impossible to Record, mute,…
The others Loop work.
Some times second Loop works… So i don’t know how to “debug”…
On SooperLooper UI, the loop is : Not Connected.
I am on Zynthian 5.1 - Vangelis updated.
Loop 2 works for me. There needs more info. Maybe you could report via the “Report Issue” button in webconf to add a github issue ticket. This adds your configuration details and guides you through adding details of how to describe the issue and steps to reproduce. It is tricky to reproduce issues without such detail.
Hi
I did a report issue.
It is a strange behaviour, it is not always the case… But often.
It is always the second loop which is “disconnected”…
I do not know what to do to understand why and when…
I have experienced the same, and gave up on understanding. Unfortunately, I have some limitations in my understanding of a lot of things, so i will not blame SooperLooper.
Hi
I found the problem
Cause i modified the length of the LOPs and it was too Much…
