Probably you have noted that ALL zynthian sites have been out of service for several hours.
Last night I was trying to solve again the stability problems with the root server (FYI, a root server is a physical machine dedicated to host virtual machines using some hypervisor technology), and did a mess with the grub configuration. Understanding and solving the problem has been a nice challenge for this morning, but finally it’s solved and i hope stability problems are gone too …
By the way, i’ve learned a little bit about grub configuration and hypervisor parameters … exactly what i was looking for this bored morning
I don’t know the exact constellation of the planets, but it must have to do with this! I currently have also much soft- and hardware problems. Why are printers so big and heavy??? I would like to throw them!
But you are lucky. It seems you do not need to sleep
I don’t think this is enough … you would program a local queue system to sync your issue requests when the github is up again. Perhaps you already did it …
Seems like you spoke too early. Significant outage this morning. At least it meant I had no excuse to start work in the kitchen (after a few hours bug squashing zynstep).
