What are the minus of keeping SoundFonts on a USB stick?
Turns into a many to many problem if you have multiple zynths.
Works as a physical backup, if properly managed.
You need to have an available USB port on the Zynth.
as I will have 2 Zynthians with different HW, putting soundfonts on a stick would let me easier keep aligned the soundfont palette for both
It’s what makes it easiest to remember for you
I’m appalling at it.
Thanks Chris
I’ll keep in mind your suggestion
