I use a USB audio interface, and the Alsa hardware number often varies when I boot it up. I then have to SSH into the device, find out the hardware number with aplay -l and edit the Zynthian conf. Is there a method to assign a static hardware ID to my interface?
Hi @walt,
Numbering may change depending if midi hw devices that are plugged in or not.
In webconf, under audio settings, advanced, change the jackd parameters from
hw:0
to
hw:K1
