Strange clicks on all the synths and presets
I am getting strange clicks on all the instruments and channels, doesnt matter mono or poly, filtered or not.
adding couple of samples where its heard clearly.
Hi @ltignis !
This report is not very useful without all the details. Probably you have read about this in other threads in this forum. I will repeat here:
  • Hardware context => What hardware are you using. All the relevant hardware.
  • Software => What zynthian version are you using. Probably Oram, but it’s good to confirm and avoid misunderstandings.
  • Steps to reproduce the issue from scratch. Engines, chains, etc.
  • All the relevant details you can. For instance, in this case you should explain how did you record this audio files.
  • A snapshot is always welcome
Please, don’t suppose we know anything about your setup or use-case. Zynthian is used in so many ways that we really need you be very specific.
For instance, how are you listening the noise? Speakers? Headphones? Did you record these audios internally with the zynthian audio recorder or you recorded from outside? In such a case, what is the full audio chain from zynthian to the speakers? Etc.
Thanks,
sorry no problem.
v5.1 the cracks appear randomly on a lot of synth engines when Zynthian is in multimode, changing the preset helps untill i make couple of parameter changes and it starts again. These crackles aren’t consistent, but you can hear them way more on polyphonic and low tones
I did record it with my audio interface getting direct signal form Zynthian to Bitwig
002-pirms.zss (35.5 KB)
Could you repeat the record with the internal recorder and compare?
Also, when noise is produced, are you seeing some red triangle or other “red” symbol in the zynthian’s status area? It’s in the top-right corner.
Could you describe with detail what is your setup? What devices are connected to zynthian? Are you using the official PSU? What SD-card (brand and model) are you using?
When you say “a lot of synth engines”, could give a list? Is there some synth engine that doesn’t produce the noises? Have you enabled the VNC interface or any MIDI network service? Are you using the internal sequencer? playing from the keyboard? Using an external sequencer?
Etc.
Details, please. If you give us the details in your first report, this process would be much more efficient. Without details, we all waste time and effort.
Thanks for your understanding,
