Sustain pedal fix to a chain? [SOLVED!]
Hi!
I’m slowly starting to get familiar with my new Zynthian V5.1. I’ve noticed the following:
I added a new instrument (piano) and can play with it. However, when I switch to the mixer view and click on “Main” on the right, my sustain pedal stops working. It only starts working again when my piano channel is active, which seems to reassign the sustain pedal to the piano.
Apparently, the pedal always affects the chain that has focus in the mixer view. Is there a way to configure it so that it is permanently assigned to a specific chain (in my case, the piano), regardless of whether that chain is selected or not?
Alright, found the Oram User Guide. I think I should read this first…:wink:
You have to options:
  • You use the MULTI mode for your device
  • You use Global MIDI-learn to learn you pedal. Click twice the “sustain” knob until you get the yellow “??#??”.
