Browse to http://zynthian.local . This doesn’t work in all devices. Many Windows-PCs and mobile devices doesn’t fully support the mDNS protocol.
If you your browser can’t find the zynthian.local address, you will then need to figure out what IP address has been assigned to your Zynthian Box. For more details, see Finding your IP address. Once you have your Zynthian’s IP address (xxx.xxx.xxx.xxx), you can browse to http://xxx.xxx.xxx.xxx . Easy,
But if you already login into your zynthian, then you only have to use the same address from your browser.
Also, from the zynthian’s command line you can use the command “ifconfig” for getting the IP assigned to your zynthian.
Hmmm… what does the picture in your rivate message mean? I think it does not work? That’s really strange, because it works for me without any problems. Double check that “CAPS-LOCK” is off.
how do I get the settings to apply the buttons in a different way from other machines, the first of my zynthian is not true zynthian, I only have a 7 "touch screen and an audioinjector card so there are no physical buttons. ?
I set the buttons to dummy and the screen to standard hdmi in the web configuration tool, I also have the audio injector and you have to enable input in alsamixer to use the input.
If you want to try my midish engine you have to install midish (to the standard user/bin if I remember correctly) then use git in zynthian-ui folder to sync with my repo and change the branch to midish-sequencer
Teddy, if you can login with SSH, then you can access the webconf with the same password, for sure!!
There is no problem at all … except perhaps you are not writing the password correctly
test log in my 2 computer webcon zynthian ip adrees pasword : raspberry ( no logins)
1.test my notebook win 10 webcon zynthian ip adrees pasword : raspberry ( no logins
2. my pc destop linux mint no log int
3 my raspberry winth raspbian os logins succes and my ky encoder module ( remove all resistor 10 k) workfine
