Teddy, if you can login with SSH, then you can access the webconf with the same password, for sure!!
There is no problem at all … except perhaps you are not writing the password correctly
I’m sorry I don’t understand what PEBCAK is
test log in my 2 computer webcon zynthian ip adrees pasword : raspberry ( no logins)
1.test my notebook win 10 webcon zynthian ip adrees pasword : raspberry ( no logins
2. my pc destop linux mint no log int
3 my raspberry winth raspbian os logins succes and my ky encoder module ( remove all resistor 10 k) workfine
If you can go to Admin
and select Network it will display the network information.
But the ip address into a web browser.
Do you see the webconf login screen?
You need to do this cos this is where you pick up the sound file you are about to create…
when I was fixing a bug for chris (who is using firefox), I had issues logging into webconf as well.
But this had something to do with no ssl and password input. Firefox rejects it.
We should provide a certificate.
I am using chrome without issues so far. But they might change the policy in the future as well.
Do we get to hear a sound sample?
Well done tedy! Really good to see it working.
But we still haven’t HEARD it working !
…Tedy … ?
even just one note …!
Came on … Tedy!!!
I’m sorry I just joined this forum because there are some busy things
Ohhhh! Welcome back, teddy!! Good to read from you again …
Did you finish your zynthian?
test zynthian with fluidsynth sound
Excellent! Congratulations!!
Which preset is it?
sadly I get video un-available on th second video.
Are you on the map yet?
Actually where is the map…?
hy wyleu gm/GS/xg automap custom sf 2(sondfont bank) load to fluidsynth
What is it if ADMIN>NETWORK INFO does not show any network info and returns to the ADMIN page by itself?
