wyleu
August 31, 2020, 3:45pm
1
https://www.raspberrypi.org/forums/viewtopic.php?t=243488
The RUN signal allows the Pi SoC to be reset,
the EN allows the PMIC to powered up and down.
the EN pin connected to 5V via a 100K 63mW resistor, RUN to 3V3 via 10K 63mW.
Update : From a Raspberry Pi engineer , the answers to the questions are as follows:
Momentarily short GLOBAL_EN to ground to restart a halted RBP4.
Momentarily short GLOBAL_EN to ground to restart a running RBP4. Usual caveats about suddenly powering off your system apply.
and something that made me laugh. . . .
wyleu
August 31, 2020, 5:03pm
2
Well it makes a little more sense now .
I can reboot the zynth from the ENABLE PIN and also reset it. BUT the 7" touchscreen does not reset simply goes stripey. The Pi reboots, indeed, I can find it on vnc and it’s makes noises properly, but no touchscreen without poweroff…
wyleu
September 1, 2020, 10:54am
3
ok. Powering the Touchscreen from a separate power supply via the small usb connector on the touchscreen allows a shutdown to be produced.
Press and hold reset button ( connects J2 ENABLE to OV )
Disconnect Screen power supply.
Reconnect screen power supply.
Release reset button
So I need a mechanism to perform this merry little dance.
