Timer for audio recorder
It would be nice to have a timer feature for the audio recorder.
This way it could be possible to record audio sources for a while, then save the file and (optional) shutdown the zynthian. A possible task is recording from a web radio overnight to listen to the content later. It would also be nice to have a recording status line with a clock of how much material has been recorded actually. This is useful for creating individual mixes of defined lengths.
Thank you!
I, the Amazing @tunagenes will now predict the future… Cue eerie theremin music…
Yes, it is coming into focus, I can’t quite make out who replied, but they said the idea has merit, and asked if you would write a feature request:
An excellent idea!
Could you prepare a feature requsst…?
Wow! You need to beware your culture’s regressive path… They may burn you as a witch! :sob:
Unfortunately I’m not on Github and I don’t want to create another online account. That’s why I posted here. Sorry.
No need to be sorry, It’s better to make a suggestion here in the forum than not at all. Maybe somone else will make a feature request. Maybe.
Hi @wyleu,
it’s not related to a problem. It’s more like an enhancement of usability.
The timer enables recording of sound sources while not being available to start and / or stop the recording. The source can be an internet radio stream or a jam session or something, that cannot be interrupted by a physical person.
The second feature, the record duration clock, enables to create recordings of a defined length while watching the clock counting. Different sound sources can play as long as the recording time is less or equal to the desired one. Possible situation: Creating a mix tape or background music playback source.
