Hey there. Im trying to build a Zynthian box to use as a Synth module for a keytar project,
and it’s giving me some real trouble.
I’m using a 4GB RPI 4, and a generic HDMI display without touch. eprom tells the pi it’s 1080p, but its not so I force 720p. Display has analog audio passthough from hdmi to a 3.5" jack, so Im planning to use that for starters until I have the funds for a better audio add-on board.
Anyway, I started by flashing the default image to my SD card and was met with the starup text, before it flashed to a black screen; inevitably loading software to the wrong non-existant display.
I forced HDMI output via the config.txt file, and set HDMI mode 4, but now it exits after trying to start the Zynthian_ui service 5 times, and offers me a login. loging in and running “startx” returns error code 1.
using rasp-config returns some interesting results. the system doesn’t recognize my display, it says nothing is connected to the HDMI port (despite the fact that its outputting through HDMI 0). it refuses to enable pixel doubling, stating that there are no connected displays. it also refuses to acknowledge any audio devices exist before booting me from the audio menu.
interestingly enough, it will still let me select a resolution, though it won’t apply it, even after rebooting, even after entering raspi-config as root.
Trying to connect the Pi to wifi so i can sh into it won’t work, as it spits more errors back at me.
(I really don’t wanna run a 30ft ethernet cable upstairs just to connect to my pi, and my PCs only ethernet port is occupied for its internet connection)
I can say with 100% certainty, that this isnt a hardware issue, as I was running everything perfectly fine on the latest stock Rasbpian image (HDMI analog audio, 720p output, pixel doubling, no overscan, internet connected fine), minuets before trying the Zynthian image.
I understand that this image is made for the per-assembled/kit Zynthians, but what do i need to do to make it work with my hardware?
