I’m not sure what is happening here, but when i try to install the latest TUS lv2 plugins and activate them through the UI, they just hang indefinately. Removing the newer ones and backing down to alpha/beta or early releases and they load just perfectly fine.
I tried Vavra, Xenia, etc and the same applies across the board. Is there anything i can try or do?
I had mixed results lately in Vangelis (Staging), with anything but the only two officially supported and integrated TUS plugins, i.e. Osirus and OsTIrus. VirtualJV (not a DSP56300 emulation software) is partially integrated, showing presets but not exposing parameters, and JE8086 is only usable via VNC.
Take into account that the respective TUS and Zynthian frameworks aren’t developing accordingly, and that basically very little maintenance effort towards the Zynthian ecosystem compatibility is being done on the DSP56300 emulation team’s part.
Thus, I am afraid that we should expect occasional inconsistencies while Vangelis (and later Tomita) grow and change, at least until the devs here take periodically the matter in their own hands.
If there is a bug, raise a ticket. Vangelis is the stable release so it should work and not be changing as rapidly as it did when it was in development. Tomita is the new development branch where you will see rapid development and change.
