Unable to find Zynthian for Webconfig [SOLVED]
Good morning to all and happy holidays if you are on vacation …
I have the same problem of accessing the web config because port 80 is NOT open.
With a network scanner I find the zinthian IP address but only port 22 is open where I can regularly access with WinSCP.
But I can not clearly make any web access if port 80 is closed, same thing with zynthian.local as the base is hijacked to the IP address. I performed various tests disconnecting the cable from the GPIO connector and leaving the raspberry 3 connected only to the power supply and to the network cable to the pc.
Some ideas?
Sorry if I have not written correctly, I’m using the google translator.
when you have ssh connection, you can "systemctl stop zynthian-webconf"
then
cd /zynthian/zynthian-webconf/
and finally
./zynthian_webconf.sh
Now you see log messages.
My guess is, that you didn’t update your system.
@jofemodo
where is the diagnosis script? :slight_smile:
Jeje! My guess is that @sevest is using an old SD image. All recent SD images have webconf running in port 80 by default :wink:
@mheidt, the disagnosis script is on the way. Give me some days …
I confirm the error. I had downloaded the image of version 2 instead of version 1 …
Now it works properly, thanks.
Somehow it became impossible for me to enter the webconf. It just keeps loading (in safari) and in Firefox it gives me an error saying that it cant connect.
I can still connect via my ftp client and with terminal thou, so there must be some connection. I also tried updating, which changed nothing
Any ideas?
I dont know if the log helps anything, but here it is:
Summary
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l
Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Mar 6 16:10:40 2018
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
./zynthian.sh: line 43: /zynthian/zynthian-my-data/midi-profiles/default.sh: No such file or directory
INFO:root:Wiring Layout PROTOTYPE-4
DEBUG:root:ZYNCODER A: [26, 25, 0, 4]
DEBUG:root:ZYNCODER B: [21, 27, 7, 3]
DEBUG:root:SWITCHES layout: [107, 23, 106, 2]
DEBUG:root:DISABLED_MIDI_IN = [’’]
DEBUG:root:ENABLED_MIDI_OUT = [‘MIDI_out’]
Zyncoder: Zynswitches poll thread created successfully
Zyncoder: MIDI tuning frequency set to 440 Hz (8192)
DEBUG:root:IGNORE CH#0 PG#0
DEBUG:root:IGNORE CH#1 PG#0
DEBUG:root:IGNORE CH#2 PG#0
DEBUG:root:IGNORE CH#0 CC#7
DEBUG:root:IGNORE CH#1 CC#7
DEBUG:root:IGNORE CH#2 CC#7
INFO:root:SWITCHES INIT…
INFO:root:SETUP GPIO SWITCH 0 => 107
INFO:root:SETUP GPIO SWITCH 1 => 23
INFO:root:SETUP GPIO SWITCH 2 => 106
INFO:root:SETUP GPIO SWITCH 3 => 2
DEBUG:root:ZCTRL ‘Layer’: 0 (0 -> 2), None, None
DEBUG:root:Snapshot Bank ‘00001-EV’ => MIDI bank 0.
DEBUG:root:ZCTRL ‘Bank’: 0 (0 -> 1), None, None
Access via ssh.
./zynthian-webconf.sh
Now you see error messages, if there are any.
ok thanks!
After doing what you said the terminal showed:
Summary
root@zynthian:/zynthian/zynthian-webconf# ./zynthian_webconf.sh
File “./zynthian_webconf.py”, line 46, in
from lib.upload_handler import UploadHandler
File “/zynthian/zynthian-webconf/lib/upload_handler.py”, line 32, in
import jsonpickle
ImportError: No module named 'jsonpickle’
is this jsonpickle something to worry about?
when I open the webconf adress in the browser the terminal doesnt show me new stuff.
I would take a new image and start from scratch.
Or you play with update_zynthian, update_zynthian_data and maybe even update_system
You are not running the latest system.
ok strange i’ve run the update two times from the zynthian. How do I know if I’m on the latest version? Is is written somewhere what the most recent is? Do I always have to update many times to reach the new version?
How does this work, update_zynthian and the others? Tried typing it in terminal but it doesnt understand me ^^
You need to search it
I recommend starting from scratch,
ok I trief the terminal update options you mentioned. Unfortunately didnt help.
I’m going to download the installer and make a fresh sd. I wish I would have constructed my zynthian in a way that makes it easier to reach it ^^
Cut a hole. That’s what the original kit has and what I did with my self made cases as well.
I reinstalled everything now. And run the zynthian_update and zynthian_update_data.sh several times. When I boot I now get the red error message.
I’m also confused that the operation system still seems to be the same like before and you said its not the recent one, right? I updated with the zynthian_gorgona_next_rbpi3_pitft28-2017-11-14 file.
I could load the initial webconf screen though! But its password protected and ‘raspberry’ doesnt work?
In the log it looks very messy now:
Summary
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Nov 14 13:27:01 2017
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jackdmp 1.9.10
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2014 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is “Don’t restrict self connect requests”
control open “hw:0” (No such file or directory)
creating alsa driver … hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
ALSA lib pcm_hw.c:1667:(_snd_pcm_hw_open) Invalid value for card
ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
JackTemporaryException : now quits…
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
jack server is not running or cannot be started
ERROR:zynautoconnect.zynthian_autoconnect:Failed to connect with Jack Server: Error initializing “Zynthian_autoconnect”: <jack.Status 0x11: failure, server_failed>
ERROR:zynautoconnect.zynthian_autoconnect:ERROR Autoconnecting: ‘NoneType’ object has no attribute ‘get_ports’
jackdmp 1.9.10
Are you sure, that your soundcard is ok and configured correctly?
is there a way to configure the soundcard without the webconf?
I don’t know how to find out if its ok. Any hints? I have an audioinjector.
What I can say is that I could still use it normally except for the webconf, but as an instrument, before I put the new image on, so I guess the soundcard is surely not completely broken
show us the logs, when you start webconf manually. Pls search the forum how to do it
cool! Now, after manually opening webconf I could also access it in the browser. Then after beeing able to select my soundcard I’m back on the boat! Next step: rocket science!
