This release try to solve some configuration problems from the previous release (Gorgona-Edge), includes the last software updates and upgrades the MOD software.
Finally, you will note that the image size is bigger although the apt cache has been cleaned. The reason is that the SFZ soundfont collection has been re-organized, fixed and updated with new ones.
I forgot to say that i’ve fixed a few bugs in the Zynthian UI MOD integration (MOD-UI engine). I hope you note some improvement, specially when using the Web UI & the Zynthian UI at once
The update should be enough, but some people had configuration problems in the last days/weeks. I’ve found some “update” problems depending on the “status” of the system. It’s difficult to make a good update system that covers every possibility and case …
You try and if it works for you, perfect. It would take some time to upgrade de MOD software. If you have problems, try to download the new one
@nack, yes, i’ve considered and will do it for the next releases @s_blakely, my torrent server is having problems these days, but i hope the problem is solved and working OK. Please, try again
