I clicked on Update Software on the Admin screen and it appeared to work. (Oct 8 21:40 PST)
I clicked on Reboot.
Now I just get the zynthian ERROR screen.
I can still ssh into the RaspberryPi.
Try updating again from CL for viewing the logs. If it doesn’t work, you could try to start with a fresh Gorgona Omega image and update again.
you need to open zynth config go to jalv page scan for new plugins and then save. mine worked after this
Then the Zynthian-UI will take the default hardcoded plugin list
A couple of points:
I’m trying to write documentation for an ordinary user. In that process I “pretend” to be not very knowledgeable when I’m using the Zynthian. Or maybe I am actually not knowledgeable about it!
When I experience something that would cause an ordinary user to panic, I report it.
Clicking on Update Software and having it appear to break my Zynthian is not a good experience.
When something like this happens, it would be more useful to provide step-by-step instructions usable by anyone on how to recover.
I get that the most obvious solution is to flash a new SDcard from the latest image.
However, I have a bunch of settings for my specific hardware (different touchscreen and different sound device) that I don’t want to lose. I have not written them down, as would have been wise.
Also I have a bunch of sound fonts and samples I don’t want to have to reload.
So I’m looking for an alternative to starting from scratch, flashing an SDcard.
I can ssh to the command line. Exactly what do I type at the command-line to cause another update to happen? Is that what I need to do to correct the error, without having to flash an SDcard?
Hi Glenn!
I would try to updata again from the command line:
/zynthian/zynthian-sys/scripts/update_zynthian.sh
http://wiki.zynthian.org/index.php/Zynthian_Box_Updating
If still getting the error, run the UI from command line and send the log output:
systemctl stop zynthian
/zynthian/zynthian-sys/sbin/zynthian.sh
http://wiki.zynthian.org/index.php/Command_Line_User_Guide#Stopping.2FStarting_the_Zynthian_UI
It’s pending over my desk to make a decent diagnostic system using the webconf tool. I will try to work on it in the next weeks
Anyway, it would be nice to have a “Common Mistakes & Reporting Errors” section in the wiki, or something like that …
BTW, i hope to have a time window for making some videos very soon
Kind Regards,
Here is the output from update_zynthian.sh
root@zynthian:/zynthian/zynthian-sys/scripts# ./update_zynthian.sh
Updating zynthian-sys …
remote: Enumerating objects: 9, done.
remote: Counting objects: 100% (9/9), done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 5 (delta 4), reused 1 (delta 0), pack-reused 0
Unpacking objects: 100% (5/5), done.
From GitHub - zynthian/zynthian-sys: System configuration scripts & files for Zynthian.
c52ed1b…dd1af33 master → origin/master
Updating 7541425…dd1af33
error: The following untracked working tree files would be overwritten by merge:
boot/overlays/waveshare32b-overlay.dtbo
boot/overlays/waveshare35a-overlay.dtbo
boot/overlays/waveshare35b-overlay.dtbo
boot/overlays/waveshare35cpld-overlay.dtbo
Please move or remove them before you can merge.
Aborting
Updating System configuration …
SOUNDCARD CONFIG =>
DISPLAY CONFIG => disable_overscan=1\n
Updating zynthian recipes …
Executing /zynthian/zynthian-sys/scripts/recipes.update/01_setup_zynthian_multil ayer.sh …
Already upgraded to multilayer!
Executing /zynthian/zynthian-sys/scripts/recipes.update/02_setup_zynthian_webcon f.sh …
Already upgraded to webconf!
Executing /zynthian/zynthian-sys/scripts/recipes.update/03_setup_zynthian_master .sh …
Already upgraded to master!
Executing /zynthian/zynthian-sys/scripts/recipes.update/04_setup_zynthian_edge.s h …
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_dexed_dcoredump.s h …
From GitHub - dcoredump/dexed.lv2: FM multi plaform/multi format plugin
- branch native-lv2 → FETCH_HEAD
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_linuxsampler.sh . …
Already updated to linuxsampler-2.0!
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_modui.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_setBfree.sh …
Updating zyncoder …
Already up-to-date.
++ Defined HAVE_WIRINGPI_LIB
++ Using wiringPI
– Configuring done
– Generating done
– Build files have been written to: /zynthian/zyncoder/build
[ 60%] Built target zyncoder
[100%] Built target zyncoder_test
Updating zynthian-ui …
remote: Enumerating objects: 12, done.
remote: Counting objects: 100% (12/12), done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 12 (delta 10), reused 12 (delta 10), pack-reused 0
Unpacking objects: 100% (12/12), done.
From GitHub - zynthian/zynthian-ui: User Interface for Zynthian
af943e0…2db8c13 master → origin/master
Updating af943e0…2db8c13
Fast-forward
zyngine/zynthian_engine_jalv.py | 20 ++++++±-------
zyngine/zynthian_engine_pianoteq.py | 3 +±
zyngui/zynthian_gui_engine.py | 47 ++++++++++++++++++++++±------------
zyngui/zynthian_gui_layer.py | 21 +++++++++±-----
zyngui/zynthian_gui_layer_options.py | 2 ±
5 files changed, 57 insertions(+), 36 deletions(-)
Updating zynthian-webconf …
remote: Enumerating objects: 10, done.
remote: Counting objects: 100% (10/10), done.
remote: Total 10 (delta 8), reused 10 (delta 8), pack-reused 0
Unpacking objects: 100% (10/10), done.
From GitHub - zynthian/zynthian-webconf: Web Configuration Tool
a9489f8…e27a621 master → origin/master
error: git-pull died of signal 13
Warning: Unit file of zynthian-webconf.service changed on disk, ‘systemctl daemo n-reload’ recommended.
root@zynthian:~# systemctl stop zynthian
root@zynthian:~# /zynthian/zynthian-sys/sbin/zynthian.sh
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l
Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Oct 9 05:55:53 2018
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
./zynthian.sh: line 43: /zynthian/zynthian-my-data/midi-profiles/default.sh: No such file or directory
INFO:root:No Wiring Layout configured. Only touch interface is available.
DEBUG:root:ZYNCODER A: [0, 0, 0, 0]
DEBUG:root:ZYNCODER B: [0, 0, 0, 0]
DEBUG:root:SWITCHES layout: [0, 0, 0, 0]
DEBUG:root:DISABLED_MIDI_IN = [’’]
DEBUG:root:ENABLED_MIDI_OUT = [‘MIDI_out’]
File “./zynthian_gui.py”, line 39, in
import zynautoconnect
File “/zynthian/zynthian-ui/zynautoconnect/init.py”, line 5, in
from zynautoconnect.zynthian_autoconnect import *
File “/zynthian/zynthian-ui/zynautoconnect/zynthian_autoconnect.py”, line 35, in
from zyngui import zynthian_gui_config
File “/zynthian/zynthian-ui/zyngui/init.py”, line 27, in
from zyngui.zynthian_gui_controller import zynthian_gui_controller
File “/zynthian/zynthian-ui/zyngui/zynthian_gui_controller.py”, line 38, in
from zyngine import zynthian_controller
File “/zynthian/zynthian-ui/zyngine/init.py”, line 30, in
from zyngine.zynthian_engine_puredata import *
File “/zynthian/zynthian-ui/zyngine/zynthian_engine_puredata.py”, line 30, in
import oyaml as yaml
ImportError: No module named ‘oyaml’
It seems that something failed during the update and oyaml package was not installed. Try this:
pip3 install oyaml
reboot
pip3 installed oyaml OK, but still get ERROR screen on reboot.
OK! I see …Try this:
cd /zynthian/zynthian-sys
rm -f ./boot/overlays/waveshare32b-overlay.dtbo
rm -f ./boot/overlays/waveshare35a-overlay.dtbo
rm -f ./boot/overlays/waveshare35b-overlay.dtbo
rm -f ./boot/overlays/waveshare35cpld-overlay.dtbo
./scripts/update_zynthian.sh
Ok that seemed to have fixed something. The update got a lot further, Installing a bunch stuff like Jack stuff, Pianoteq.
Then the ssh connection died at this point:
Get:10 http://mirrordirector.raspbian.org/raspbian/ jessie/main libatomic1 armhf 4.9.2-10+deb8u1 [6,806 B]
Get:11 http://mirrordirector.raspbian.org/raspbian/ jessie/main libasan1 armhf 4 .9.2-10+deb8u1 [165 kB]
Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main libubsan0 armhf 4.9.2-10+deb8u1 [68.3 kB]
Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main cpp-4.9 armhf 4. 9.2-10+deb8u1 [4,271 kB]
Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main g+±4.9 armhf 4. 9.2-10+deb8u1 [11.9 MB]
Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main gcc-4.9 armhf 4. 9.2-10+deb8u1 [4,449 kB]
16% [14 g+±4.9 5,583 kB/11.9 MB 47%] [Connecting to mirrors.syringanetworks.ne
UPDATE: I fixed this isssue by running:
sudo update-ca-certificates
I’m running /zynthian/zynthian-sys/scripts/update_zynthian.sh
I’m getting this error:
fatal: unable to access ‘https://github.com/zynthian/zynthian-webconf.git/’: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
Webconf has a backup/restore section. In case you want to start with a fresh sd
Can’t access Webconf as I’m still getting the ERROR page.
So I think I’ve got it updated OK. But it still gives the ERROR page.
Here’s the output from running update:
root@zynthian:~# /zynthian/zynthian-sys/scripts/update_zynthian.sh
Already up-to-date.
Executing /zynthian/zynthian-sys/scripts/recipes.update/00_install_packages.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/01_setup_zynthian_multilayer.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/02_setup_zynthian_webconf.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/03_setup_zynthian_master.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/04_setup_zynthian_edge.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/05_setup_zynthian_omega.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/06_setup_zynthian_beyond.sh …
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_dexed_dcoredump.sh …
From https://github.com/dcoredump/dexed
- branch native-lv2 -> FETCH_HEAD
Executing /zynthian/zynthian-sys/scripts/recipes.update/update_linuxsampler.sh …
Updating zynthian-data …
Already up-to-date.
SOUNDCARD CONFIG =>
Aeolus Waves already exist!
Updating zyncoder …
Already up-to-date.
++ Using wiringPI
– Configuring done
– Generating done
Already up-to-date.
root@zynthian:~#
And here what I get when I run
Current Operating System: Linux zynthian 4.14.74-v7+ #1149 SMP Mon Oct 8 17:39:42 BST 2018 armv7l
Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
(==) Log file: “/var/log/Xorg.0.log”, Time: Thu Oct 11 00:05:07 2018
Zyncoder: Zynswitches poll thread created successfully
Cannot open ZynMidiRouter client
ZynMidiRouter: Error connecting with jack server.
ZynMidiRouter: MIDI tuning frequency set to 440 Hz (8192)
./zynthian.sh: line 124: 21603 Segmentation fault ./zynthian_gui.py
OK Thanks guys. Got it working.
Did a Data Backup and a System Backup using Webconf.
I have an ERROR after the update too. Maybe someone can advise me were to dig ? Installing fresh Gorgona image might be not easy for me till 27.10…
Here are the logs:
Current Operating System: Linux zynthian 4.14.71-v7+ #1145 SMP Fri Sep 21 15:38:35 BST 2018 armv7l
Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Oct 12 16:10:22 2018
INFO:root:Wiring Layout MCP23017_ENCODERS
DEBUG:root:ZYNCODER A: [102, 105, 110, 113]
DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
DEBUG:root:SWITCHES layout: [100, 103, 108, 111]
DEBUG:root:ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’, ‘a2j:Midi_Through_[14]_(playback):_Midi_Through_Port-0’]
INFO:root:SWITCHES INIT…
INFO:root:SETUP GPIO SWITCH 0 => 100
INFO:root:SETUP GPIO SWITCH 1 => 103
INFO:root:SETUP GPIO SWITCH 2 => 108
INFO:root:SETUP GPIO SWITCH 3 => 111
Fontconfig warning: ignoring UTF-8: not a valid region tag
INFO:root:STOPPING QMIDINET
File “./zynthian_gui.py”, line 673, in <module>
zyngui.start()
File “./zynthian_gui.py”, line 149, in start
self.screens[‘engine’]=zynthian_gui_engine()
File “/zynthian/zynthian-ui/zyngui/zynthian_gui_engine.py”, line 58, in init
self.init_engine_info()
File “/zynthian/zynthian-ui/zyngui/zynthian_gui_engine.py”, line 84, in init_engine_info
if plugin_info[‘TYPE’]==self.engine_type or self.engine_type is None:
TypeError: string indices must be integers
after that it goes in the loop
Hi Andreii!
You should try to “search for new plugins” and “save” from the webconf. It will regenerate the related configuración files.
Restart your zynthian …
