I want to pull in the latest bleeding edge synth from the ZynAddSubFX master branch, because there are a couple of new features I want to try out, but I’m not sure the best way to get it into the Zynthian:
Pull the ZynAddSubFX repo into the RPi4 and build it locally?
I can confirm that it does build out of the box, I just followed the build instructions on the zynaddsubfx github home page and it built and installed fine. Thanks for the tip on removing the existing installation first.
The only problem I encountered was loading a new snapshot after installing the new version, something went wrong and it seemed to hang, but it loaded fine after a reboot so I think it has something to do with the version that was installed was not the version running at the time.
