I have a V1 KIT, and I am looking to “refresh” it…
The kit is complete, except the Raspberry and the DAC…
I am looking to upgrade it with a newer Raspberry and a compatible DAC…
Has anyone already done this ?
Thanks in advance…
Thanks in advance…
I have found a HifiBerry DAC + on Amazon and have bought it…
I have a RaspBerryPi 3B+ and will replace the missing RPi 2…
The GPIO are compatibles for all RPi 2/3/4…
The box of V1 KIT may only works with RPi 2/3 (holes)…
Now I am trying to wire all the GPIO of the V1 KIT with the Wiki documentaiton at Building a Zynthian Box using an official Kit - ZynthianWiki
I am still a little lost !
The Wiki Photos and the Fritzing schéma do not look the same…
The Electrical Schéma also : https://wiki.zynthian.org/images/f/f9/Zynthian_scheme_GPIO.png
What must I follow to wire my GPIO correctly with the latest software ?
Thanks for the help and for any advice…
@jofemodo Can you, please, help on this ?
Is there any error on the Photo of the Wiki of the V1 KIT ?
Is there any error on the Fritzing or Electrical Schema ?
Can anybody point me on the right direction ?
Thanks in advance…
elif kit_version=="V1":
soundcard_name = "HifiBerry DAC+"
display_name = "PiTFT 2.8 Resistive"
wiring_layout = "PROTOTYPE-4"
["PROTOTYPE-4", {
'ZYNTHIAN_WIRING_ENCODER_A': "26,25,0,4",
'ZYNTHIAN_WIRING_ENCODER_B': "21,27,7,3",
'ZYNTHIAN_WIRING_SWITCHES': "107,23,106,2"
Hi Gandalf!
AFAIK, the wiki’s tutorial for building the V1 is accurate.
What is exactly your problem?
Oups, I do not view the Connection Tables at the end of the Kiwi page !
I can double checks all…
I was confused about the pin1 of each components.
I have deducted that this is the square pin of the controllers, and from the photos.
I will have now to solder the GPIO header on a new DAC (my first one freeze !?)
The main problem is that my V1 KIT is reversed from the photos on the Wiki…
I think I have it correctly connected now (after a lot of attempt and reverse of links)…
The main PIN1 of each components is not really advertised efficiently…
The Photos and the Schémas of the wiki help to get it all correctly (I suppose)…
I still get problem with the latest system ! going to flash again from scratch and set to V1 KIT and reboot to (cross fingering…) get it to live !
After a Hardware config from the WEBUI to V1KIT…
and a Reboot…
I get now push select and push back working, but not the rotating…???
Restarting UI in normal mode
Restarting UI in debug mode
-- Logs begin at Tue 2021-08-17 09:40:15 BST. --
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: State 'stop-sigterm' timed out. Killing.
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: Killing process 1592 (startx) with signal SIGKILL.
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: Killing process 1621 (xinit) with signal SIGKILL.
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: Killing process 1622 (Xorg) with signal SIGKILL.
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: Killing process 1634 (zynthian.sh) with signal SIGKILL.
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: Killing process 1643 (zynthian_gui.py) with signal SIGKILL.
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=killed, status=9/KILL
Aug 17 09:44:55 zynthian systemd[1]: zynthian_debug.service: Failed with result 'exit-code'.
Aug 17 09:44:55 zynthian systemd[1]: Stopped Zynthian User Interface (DEBUG).
Aug 17 09:45:37 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Aug 17 09:45:37 zynthian startx[2087]: X.Org X Server 1.20.4
Aug 17 09:45:37 zynthian startx[2087]: X Protocol Version 11, Revision 0
Aug 17 09:45:37 zynthian startx[2087]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Aug 17 09:45:37 zynthian startx[2087]: Current Operating System: Linux zynthian 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l
Aug 17 09:45:37 zynthian startx[2087]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 09:45:37 zynthian startx[2087]: Build Date: 07 July 2020 09:38:51PM
Aug 17 09:45:37 zynthian startx[2087]: xorg-server 2:1.20.4-1+rpt2 (https://www.debian.org/support)
Aug 17 09:45:37 zynthian startx[2087]: Current version of pixman: 0.36.0
Aug 17 09:45:37 zynthian startx[2087]: Before reporting problems, check http://wiki.x.org
Aug 17 09:45:37 zynthian startx[2087]: to make sure that you have the latest version.
Aug 17 09:45:37 zynthian startx[2087]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 09:45:37 zynthian startx[2087]: (++) from command line, (!!) notice, (II) informational,
Aug 17 09:45:37 zynthian startx[2087]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 09:45:37 zynthian startx[2087]: (==) Log file: "/var/log/Xorg.1.log", Time: Tue Aug 17 09:45:37 2021
Aug 17 09:45:37 zynthian startx[2087]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 09:45:37 zynthian startx[2087]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 09:45:38 zynthian startx[2087]: Unable to connect to X server
Aug 17 09:45:38 zynthian startx[2087]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 17 09:45:38 zynthian startx[2087]: INFO:zynthian_gui_config.<module>: Wiring Layout PROTOTYPE-4
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.<module>: ZYNCODER A: [26, 25, 0, 4]
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.<module>: ZYNCODER B: [21, 27, 7, 3]
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.<module>: SWITCHES layout: [107, 23, 106, 2]
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 17 09:45:38 zynthian startx[2087]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 17 09:45:40 zynthian startx[2087]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 09:45:40 zynthian startx[2087]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Aug 17 09:45:40 zynthian startx[2087]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#simple> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 09:45:40 zynthian startx[2087]: lilv_world_load_bundle(): warning: Ignoring bundle <file:///zynthian/zynthian-plugins/lv2/b_synth.lv2/>
Aug 17 09:45:40 zynthian startx[2087]: lilv_world_load_bundle(): note: Newer version of <http://gareus.org/oss/lv2/b_synth> loaded from <file:///zynthian/zynthian-plugins/lv2/b_synth/>
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Aug 17 09:45:42 zynthian startx[2087]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Aug 17 09:45:42 zynthian startx[2087]: libjackpeak registering as 'jackpeak'.
Aug 17 09:45:42 zynthian startx[2087]: libjackpeak created input ports
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui.zynswitches_init: SWITCHES INIT...
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 0 => wpGPIO 107
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 1 => wpGPIO 23
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 2 => wpGPIO 106
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 3 => wpGPIO 2
Aug 17 09:45:42 zynthian startx[2087]: INFO:zynthian_gui.zynswitches_midi_setup: MIDI SWITCHES SETUP...
Aug 17 09:45:43 zynthian startx[2087]: DEBUG:zynthian_engine_mixer.get_controllers_dict: MIXER CTRL LIST: ['Digital Left', 'Digital Right']
Aug 17 09:45:43 zynthian startx[2087]: DEBUG:zynthian_engine_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Digital_0 => 100
Aug 17 09:45:43 zynthian startx[2087]: DEBUG:zynthian_engine_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Digital_1 => 100
Aug 17 09:45:43 zynthian startx[2087]: DEBUG:zynthian_engine_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'Digital' 'Playback' 100%,100% unmute
Aug 17 09:45:43 zynthian startx[2087]: INFO:zynthian_gui_admin.stop_rbpi_headphones: STOPPING RBPI HEADPHONES
Aug 17 09:45:43 zynthian startx[2087]: INFO:zynthian_gui_admin.stop_vncserver: STOPPING VNC SERVICES
Aug 17 09:45:44 zynthian startx[2087]: INFO:zynthian_gui_midi_recorder.__init__: midi recorder created
Aug 17 09:45:44 zynthian startx[2087]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Aug 17 09:45:44 zynthian startx[2087]: INFO:zynthian_gui_admin.stop_rtpmidi: STOPPING RTP-MIDI
Aug 17 09:45:44 zynthian startx[2087]: INFO:zynthian_gui_admin.stop_qmidinet: STOPPING QMIDINET
Aug 17 09:45:44 zynthian startx[2087]: INFO:zynthian_gui_admin.stop_touchosc2midi: STOPPING touchosc2midi
Aug 17 09:45:45 zynthian startx[2087]: INFO:zynthian_gui_admin.stop_aubionotes: STOPPING aubionotes
Aug 17 09:45:45 zynthian startx[2087]: DEBUG:zynthian_gui_controller.config: ZCTRL 'Main': 0 (0 -> 9), None, None
Aug 17 09:46:40 zynthian startx[2087]: INFO:zynthian_gui.zynswitch_short: Short Switch 3
Aug 17 09:46:40 zynthian startx[2087]: INFO:zynthian_gui_main.layers: Layers
Aug 17 09:46:41 zynthian startx[2087]: DEBUG:zynthian_gui_controller.config: ZCTRL 'Layer': 0 (0 -> 8), None, None
# # ZynthianOS: Built on os.zynthian.org
# ## # Timestamp: 2020-09-05
# ## # # ## # Optimized: Raspberry Pi 3 Model B Plus
### # # # # # # ### Kit: V1
# # # # # # # # # # Display: PiTFT 2.8 Resistive
# ## # # # # ## # Soundcard: HifiBerry DAC+
# ## ## # Wiring Layout: PROTOTYPE-4
zynthian-ui: stable (b2f6a7)
zynthian-webconf: stable (153a02)
zyncoder: stable (d852c8)
zynthian-sys: stable (aefaf9)
zynthian-data: stable (f71259)
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Found this : Updating a legacy v1 kit to the latest stable release - #3 by jofemodo
Will try now…
Checked test in repositories menu…
Force update… in progress !
Updating zynthian-sys ...
Already up to date.
Executing custom update recipes ...
Executing /zynthian/zynthian-sys/scripts/recipes.update.buster/00_install_packages.sh ...
Running Flag Actions from '/zynthian/zynthian-sys/scripts/update_zynthian.sh'...
Update Complete.
Rebooting… (cross fingered)
all working ! except the rotating of select !!!
Now, I get ZYNTHIAN ERROR (with IP ok) AT BOOT… and loop on it…
on sometimes loop in Zynthian boot screen, withou error on screen :
-- Logs begin at Thu 2019-02-14 10:11:59 GMT. --
Aug 17 11:02:07 zynthian startx[1916]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:07 zynthian startx[1916]: Current version of pixman: 0.36.0
Aug 17 11:02:07 zynthian startx[1916]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:07 zynthian startx[1916]: to make sure that you have the latest version.
Aug 17 11:02:07 zynthian startx[1916]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:07 zynthian startx[1916]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:07 zynthian startx[1916]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:07 zynthian startx[1916]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:07 2021
Aug 17 11:02:07 zynthian startx[1916]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:07 zynthian startx[1916]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:07 zynthian startx[1916]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:07 zynthian startx[1916]: Zooming image by 100%...done
Aug 17 11:02:07 zynthian startx[1916]: Merging...didn't find evidence of prior run.
Aug 17 11:02:07 zynthian startx[1916]: done
Aug 17 11:02:07 zynthian startx[1916]: Building XImage...done
Aug 17 11:02:09 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:09 zynthian startx[1916]: xinit: connection to X server lost
Aug 17 11:02:09 zynthian startx[1916]: [1B blob data]
Aug 17 11:02:09 zynthian startx[1916]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:10 zynthian startx[1916]: xinit: unexpected signal 15
Aug 17 11:02:10 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:10 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:10 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:10 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:10 zynthian startx[1983]: X.Org X Server 1.20.4
Aug 17 11:02:10 zynthian startx[1983]: X Protocol Version 11, Revision 0
Aug 17 11:02:10 zynthian startx[1983]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:02:10 zynthian startx[1983]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:02:10 zynthian startx[1983]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:02:10 zynthian startx[1983]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:02:10 zynthian startx[1983]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:10 zynthian startx[1983]: Current version of pixman: 0.36.0
Aug 17 11:02:10 zynthian startx[1983]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:10 zynthian startx[1983]: to make sure that you have the latest version.
Aug 17 11:02:10 zynthian startx[1983]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:10 zynthian startx[1983]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:10 zynthian startx[1983]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:10 zynthian startx[1983]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:10 2021
Aug 17 11:02:10 zynthian startx[1983]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:10 zynthian startx[1983]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:10 zynthian startx[1983]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:10 zynthian startx[1983]: Zooming image by 100%...done
Aug 17 11:02:10 zynthian startx[1983]: Merging...didn't find evidence of prior run.
Aug 17 11:02:10 zynthian startx[1983]: done
Aug 17 11:02:10 zynthian startx[1983]: Building XImage...done
Aug 17 11:02:12 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:12 zynthian startx[1983]: xinit: connection to X server lost
Aug 17 11:02:12 zynthian startx[1983]: [1B blob data]
Aug 17 11:02:12 zynthian startx[1983]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:13 zynthian startx[1983]: xinit: unexpected signal 15
Aug 17 11:02:13 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:13 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:13 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:13 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:13 zynthian startx[2048]: X.Org X Server 1.20.4
Aug 17 11:02:13 zynthian startx[2048]: X Protocol Version 11, Revision 0
Aug 17 11:02:13 zynthian startx[2048]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:02:13 zynthian startx[2048]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:02:13 zynthian startx[2048]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:02:13 zynthian startx[2048]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:02:13 zynthian startx[2048]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:13 zynthian startx[2048]: Current version of pixman: 0.36.0
Aug 17 11:02:13 zynthian startx[2048]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:13 zynthian startx[2048]: to make sure that you have the latest version.
Aug 17 11:02:13 zynthian startx[2048]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:13 zynthian startx[2048]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:13 zynthian startx[2048]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:13 zynthian startx[2048]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:13 2021
Aug 17 11:02:13 zynthian startx[2048]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:13 zynthian startx[2048]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:13 zynthian startx[2048]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:13 zynthian startx[2048]: Zooming image by 100%...done
Aug 17 11:02:13 zynthian startx[2048]: Merging...didn't find evidence of prior run.
Aug 17 11:02:13 zynthian startx[2048]: done
Aug 17 11:02:13 zynthian startx[2048]: Building XImage...done
Aug 17 11:02:15 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:15 zynthian startx[2048]: xinit: connection to X server lost
Aug 17 11:02:15 zynthian startx[2048]: [1B blob data]
Aug 17 11:02:15 zynthian startx[2048]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:16 zynthian startx[2048]: xinit: unexpected signal 15
Aug 17 11:02:16 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:16 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:16 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:16 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:16 zynthian startx[2108]: X.Org X Server 1.20.4
Aug 17 11:02:16 zynthian startx[2108]: X Protocol Version 11, Revision 0
Aug 17 11:02:16 zynthian startx[2108]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:02:16 zynthian startx[2108]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:02:16 zynthian startx[2108]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:02:16 zynthian startx[2108]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:02:16 zynthian startx[2108]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:16 zynthian startx[2108]: Current version of pixman: 0.36.0
Aug 17 11:02:16 zynthian startx[2108]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:16 zynthian startx[2108]: to make sure that you have the latest version.
Aug 17 11:02:16 zynthian startx[2108]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:16 zynthian startx[2108]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:16 zynthian startx[2108]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:16 zynthian startx[2108]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:16 2021
Aug 17 11:02:16 zynthian startx[2108]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:16 zynthian startx[2108]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:16 zynthian startx[2108]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:16 zynthian startx[2108]: Zooming image by 100%...done
Aug 17 11:02:16 zynthian startx[2108]: Merging...didn't find evidence of prior run.
Aug 17 11:02:16 zynthian startx[2108]: done
Aug 17 11:02:16 zynthian startx[2108]: Building XImage...done
Aug 17 11:02:18 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:18 zynthian startx[2108]: xinit: connection to X server lost
Aug 17 11:02:18 zynthian startx[2108]: [1B blob data]
Aug 17 11:02:18 zynthian startx[2108]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:19 zynthian startx[2108]: xinit: unexpected signal 15
Aug 17 11:02:19 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:19 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:19 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:19 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:19 zynthian startx[2168]: X.Org X Server 1.20.4
Aug 17 11:02:19 zynthian startx[2168]: X Protocol Version 11, Revision 0
Aug 17 11:02:19 zynthian startx[2168]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:02:19 zynthian startx[2168]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:02:19 zynthian startx[2168]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:02:19 zynthian startx[2168]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:02:19 zynthian startx[2168]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:19 zynthian startx[2168]: Current version of pixman: 0.36.0
Aug 17 11:02:19 zynthian startx[2168]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:19 zynthian startx[2168]: to make sure that you have the latest version.
Aug 17 11:02:19 zynthian startx[2168]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:19 zynthian startx[2168]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:19 zynthian startx[2168]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:19 zynthian startx[2168]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:19 2021
Aug 17 11:02:19 zynthian startx[2168]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:19 zynthian startx[2168]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:19 zynthian startx[2168]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:19 zynthian startx[2168]: Zooming image by 100%...done
Aug 17 11:02:19 zynthian startx[2168]: Merging...didn't find evidence of prior run.
Aug 17 11:02:19 zynthian startx[2168]: done
Aug 17 11:02:19 zynthian startx[2168]: Building XImage...done
Aug 17 11:02:21 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:21 zynthian startx[2168]: xinit: connection to X server lost
Aug 17 11:02:21 zynthian startx[2168]: [1B blob data]
Aug 17 11:02:21 zynthian startx[2168]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:22 zynthian startx[2168]: xinit: unexpected signal 15
Aug 17 11:02:22 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:22 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:22 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:22 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:22 zynthian startx[2231]: X.Org X Server 1.20.4
Aug 17 11:02:22 zynthian startx[2231]: X Protocol Version 11, Revision 0
Aug 17 11:02:22 zynthian startx[2231]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:02:22 zynthian startx[2231]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:02:22 zynthian startx[2231]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:02:22 zynthian startx[2231]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:02:22 zynthian startx[2231]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:22 zynthian startx[2231]: Current version of pixman: 0.36.0
Aug 17 11:02:22 zynthian startx[2231]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:22 zynthian startx[2231]: to make sure that you have the latest version.
Aug 17 11:02:22 zynthian startx[2231]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:22 zynthian startx[2231]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:22 zynthian startx[2231]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:22 zynthian startx[2231]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:22 2021
Aug 17 11:02:22 zynthian startx[2231]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:22 zynthian startx[2231]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:22 zynthian startx[2231]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:22 zynthian startx[2231]: Zooming image by 100%...done
Aug 17 11:02:22 zynthian startx[2231]: Merging...didn't find evidence of prior run.
Aug 17 11:02:22 zynthian startx[2231]: done
Aug 17 11:02:22 zynthian startx[2231]: Building XImage...done
Aug 17 11:02:24 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:24 zynthian startx[2231]: xinit: connection to X server lost
Aug 17 11:02:24 zynthian startx[2231]: [1B blob data]
Aug 17 11:02:24 zynthian startx[2231]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:25 zynthian startx[2231]: xinit: unexpected signal 15
Aug 17 11:02:25 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:25 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:25 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:25 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:25 zynthian startx[2295]: X.Org X Server 1.20.4
Aug 17 11:02:25 zynthian startx[2295]: X Protocol Version 11, Revision 0
Aug 17 11:02:25 zynthian startx[2295]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:02:25 zynthian startx[2295]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:02:25 zynthian startx[2295]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:02:25 zynthian startx[2295]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:02:25 zynthian startx[2295]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:25 zynthian startx[2295]: Current version of pixman: 0.36.0
Aug 17 11:02:25 zynthian startx[2295]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:25 zynthian startx[2295]: to make sure that you have the latest version.
Aug 17 11:02:25 zynthian startx[2295]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:25 zynthian startx[2295]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:25 zynthian startx[2295]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:25 zynthian startx[2295]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:25 2021
Aug 17 11:02:25 zynthian startx[2295]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:25 zynthian startx[2295]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:25 zynthian startx[2295]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:25 zynthian startx[2295]: Zooming image by 100%...done
Aug 17 11:02:25 zynthian startx[2295]: Merging...didn't find evidence of prior run.
Aug 17 11:02:25 zynthian startx[2295]: done
Aug 17 11:02:25 zynthian startx[2295]: Building XImage...done
Aug 17 11:02:27 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:27 zynthian startx[2295]: xinit: connection to X server lost
Aug 17 11:02:27 zynthian startx[2295]: [1B blob data]
Aug 17 11:02:27 zynthian startx[2295]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:28 zynthian startx[2295]: xinit: unexpected signal 15
Aug 17 11:02:28 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:28 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:28 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:28 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:28 zynthian startx[2356]: X.Org X Server 1.20.4
Aug 17 11:02:28 zynthian startx[2356]: X Protocol Version 11, Revision 0
Aug 17 11:02:28 zynthian startx[2356]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:02:28 zynthian startx[2356]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:02:28 zynthian startx[2356]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:02:28 zynthian startx[2356]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:02:28 zynthian startx[2356]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:02:28 zynthian startx[2356]: Current version of pixman: 0.36.0
Aug 17 11:02:28 zynthian startx[2356]: Before reporting problems, check http://wiki.x.org
Aug 17 11:02:28 zynthian startx[2356]: to make sure that you have the latest version.
Aug 17 11:02:28 zynthian startx[2356]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:02:28 zynthian startx[2356]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:02:28 zynthian startx[2356]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:02:28 zynthian startx[2356]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:02:28 2021
Aug 17 11:02:28 zynthian startx[2356]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:02:28 zynthian startx[2356]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:02:28 zynthian startx[2356]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:02:28 zynthian startx[2356]: Zooming image by 100%...done
Aug 17 11:02:28 zynthian startx[2356]: Merging...didn't find evidence of prior run.
Aug 17 11:02:28 zynthian startx[2356]: done
Aug 17 11:02:29 zynthian startx[2356]: Building XImage...done
Aug 17 11:02:30 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:02:30 zynthian startx[2356]: xinit: connection to X server lost
Aug 17 11:02:30 zynthian startx[2356]: [1B blob data]
Aug 17 11:02:30 zynthian startx[2356]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:02:31 zynthian startx[2356]: xinit: unexpected signal 15
Aug 17 11:02:31 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:02:31 zynthian systemd[1]: zynthian.service: Failed with result 'exit-code'.
Aug 17 11:02:31 zynthian systemd[1]: Stopped Zynthian User Interface.
Aug 17 11:02:31 zynthian systemd[1]: Started Zynthian User Interface.
Aug 17 11:02:31 zynthian startx[2417]: X.Org X Server 1.20.4
Aug 17 11:02:31 zynthian startx[2417]: X Protocol Version 11, Revision 0
root@zynthian:~# service zynthian status
● zynthian.service - Zynthian User Interface
Loaded: loaded (/etc/systemd/system/zynthian.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2021-08-17 11:04:25 BST; 1s ago
Main PID: 4844 (startx)
Tasks: 14 (limit: 2059)
CGroup: /system.slice/zynthian.service
├─4844 /bin/sh /usr/bin/startx ./zynthian.sh
├─4865 xinit ./zynthian.sh -- /etc/X11/xinit/xserverrc :0 -auth /tmp/serverauth.EWKVxxN3dj
├─4866 /usr/lib/xorg/Xorg -nolisten tcp :0 -auth /tmp/serverauth.EWKVxxN3dj
├─4880 /bin/bash ./zynthian.sh
└─4891 /usr/bin/python3 ./zynthian_gui.py
Aug 17 11:04:25 zynthian startx[4844]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:04:25 zynthian startx[4844]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:04:25 zynthian startx[4844]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:04:25 2021
Aug 17 11:04:25 zynthian startx[4844]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:04:25 zynthian startx[4844]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:04:25 zynthian startx[4844]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:04:25 zynthian startx[4844]: Zooming image by 100%...done
Aug 17 11:04:25 zynthian startx[4844]: Merging...didn't find evidence of prior run.
Aug 17 11:04:25 zynthian startx[4844]: done
Aug 17 11:04:25 zynthian startx[4844]: Building XImage...done
Aug 17 11:09:46 zynthian startx[10355]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:09:46 zynthian startx[10355]: Zooming image by 100%...done
Aug 17 11:09:46 zynthian startx[10355]: Merging...didn't find evidence of prior run.
Aug 17 11:09:46 zynthian startx[10355]: done
Aug 17 11:09:46 zynthian startx[10355]: Building XImage...done
Aug 17 11:09:47 zynthian systemd[1]: Stopping Zynthian User Interface...
Aug 17 11:09:47 zynthian startx[10355]: xinit: connection to X server lost
Aug 17 11:10:09 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Aug 17 11:10:09 zynthian startx[10523]: X.Org X Server 1.20.4
Aug 17 11:10:09 zynthian startx[10523]: X Protocol Version 11, Revision 0
Aug 17 11:10:09 zynthian startx[10523]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:10:09 zynthian startx[10523]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:10:09 zynthian startx[10523]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:10:09 zynthian startx[10523]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:10:09 zynthian startx[10523]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:10:09 zynthian startx[10523]: Current version of pixman: 0.36.0
Aug 17 11:10:09 zynthian startx[10523]: Before reporting problems, check http://wiki.x.org
Aug 17 11:10:09 zynthian startx[10523]: to make sure that you have the latest version.
Aug 17 11:10:09 zynthian startx[10523]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:10:09 zynthian startx[10523]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:10:09 zynthian startx[10523]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:10:09 zynthian startx[10523]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:10:09 2021
Aug 17 11:10:09 zynthian startx[10523]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:10:09 zynthian startx[10523]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:10:10 zynthian startx[10523]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:10:10 zynthian startx[10523]: Zooming image by 100%...done
Aug 17 11:10:10 zynthian startx[10523]: Merging...didn't find evidence of prior run.
Aug 17 11:10:10 zynthian startx[10523]: done
Aug 17 11:10:10 zynthian startx[10523]: Building XImage...done
Aug 17 11:10:10 zynthian startx[10523]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 17 11:10:10 zynthian startx[10523]: INFO:zynthian_gui_config.<module>: Wiring Layout PROTOTYPE-4
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: ZYNCODER A: [26, 25, 0, 4]
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: ZYNCODER B: [21, 27, 7, 3]
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: SWITCHES layout: [107, 23, 106, 2]
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 17 11:10:10 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 17 11:10:11 zynthian systemd[1]: Stopping Zynthian User Interface (DEBUG)...
Aug 17 11:10:11 zynthian startx[10523]: Terminated
Aug 17 11:10:12 zynthian startx[10523]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit
Aug 17 11:10:12 zynthian startx[10523]: Zooming image by 100%...done
Aug 17 11:10:12 zynthian startx[10523]: Merging...done
Aug 17 11:10:12 zynthian startx[10523]: Building XImage...done
Aug 17 11:10:16 zynthian startx[10523]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 17 11:10:16 zynthian startx[10523]: INFO:zynthian_gui_config.<module>: Wiring Layout PROTOTYPE-4
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: ZYNCODER A: [26, 25, 0, 4]
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: ZYNCODER B: [21, 27, 7, 3]
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: SWITCHES layout: [107, 23, 106, 2]
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 17 11:10:16 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 17 11:10:17 zynthian startx[10523]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 11:10:17 zynthian startx[10523]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Aug 17 11:10:17 zynthian startx[10523]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#simple> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 11:10:17 zynthian startx[10523]: lilv_world_load_bundle(): warning: Ignoring bundle <file:///zynthian/zynthian-plugins/lv2/b_synth.lv2/>
Aug 17 11:10:17 zynthian startx[10523]: lilv_world_load_bundle(): note: Newer version of <http://gareus.org/oss/lv2/b_synth> loaded from <file:///zynthian/zynthian-plugins/lv2/b_synth/>
Aug 17 11:10:20 zynthian startx[10523]: Cannot connect to server socket err = No such file or directory
Aug 17 11:10:20 zynthian startx[10523]: Cannot connect to server request channel
Aug 17 11:10:20 zynthian startx[10523]: jack server is not running or cannot be started
Aug 17 11:10:20 zynthian startx[10523]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 11:10:20 zynthian startx[10523]: libzynseq failed to start jack client: 17
Aug 17 11:10:20 zynthian startx[10523]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Aug 17 11:10:20 zynthian startx[10523]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Aug 17 11:10:20 zynthian startx[10523]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Aug 17 11:10:20 zynthian startx[10523]: libjackpeak failed to start jack client: 17
Aug 17 11:10:20 zynthian startx[10523]: New instance of zynseq
Aug 17 11:10:20 zynthian startx[10523]: **zynseq initialising as zynthstep**
Aug 17 11:10:20 zynthian startx[10523]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit
Aug 17 11:10:20 zynthian startx[10523]: Zooming image by 100%...done
Aug 17 11:10:20 zynthian startx[10523]: Merging...done
Aug 17 11:10:20 zynthian startx[10523]: Building XImage...done
Aug 17 11:10:24 zynthian startx[10523]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 17 11:10:24 zynthian startx[10523]: INFO:zynthian_gui_config.<module>: Wiring Layout PROTOTYPE-4
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: ZYNCODER A: [26, 25, 0, 4]
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: ZYNCODER B: [21, 27, 7, 3]
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.<module>: SWITCHES layout: [107, 23, 106, 2]
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 17 11:10:24 zynthian startx[10523]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 17 11:10:26 zynthian startx[10523]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 11:10:26 zynthian startx[10523]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Aug 17 11:10:26 zynthian startx[10523]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#simple> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 11:10:26 zynthian startx[10523]: lilv_world_load_bundle(): warning: Ignoring bundle <file:///zynthian/zynthian-plugins/lv2/b_synth.lv2/>
Aug 17 11:10:26 zynthian startx[10523]: lilv_world_load_bundle(): note: Newer version of <http://gareus.org/oss/lv2/b_synth> loaded from <file:///zynthian/zynthian-plugins/lv2/b_synth/>
Aug 17 11:10:28 zynthian startx[10523]: Cannot connect to server socket err = No such file or directory
Aug 17 11:10:28 zynthian startx[10523]: Cannot connect to server request channel
Aug 17 11:10:28 zynthian startx[10523]: jack server is not running or cannot be started
Aug 17 11:10:28 zynthian startx[10523]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 11:10:28 zynthian startx[10523]: libzynseq failed to start jack client: 17
Aug 17 11:10:28 zynthian startx[10523]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Aug 17 11:10:28 zynthian startx[10523]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Aug 17 11:10:28 zynthian startx[10523]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Aug 17 11:10:28 zynthian startx[10523]: libjackpeak failed to start jack client: 17
Aug 17 11:10:28 zynthian startx[10523]: New instance of zynseq
Aug 17 11:10:28 zynthian startx[10523]: **zynseq initialising as zynthstep**
Aug 17 11:10:28 zynthian startx[10523]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit
Aug 17 11:10:28 zynthian startx[10523]: Zooming image by 100%...done
Aug 17 11:10:28 zynthian startx[10523]: Merging...done
Aug 17 11:10:28 zynthian startx[10523]: Building XImage...done
Aug 17 11:10:31 zynthian systemd[1]: zynthian_debug.service: Stopping timed out. Terminating.
Aug 17 11:10:31 zynthian systemd[1]: zynthian_debug.service: Control process exited, code=killed, status=15/TERM
Aug 17 11:10:31 zynthian startx[10523]: xinit: connection to X server lost
Aug 17 11:10:31 zynthian startx[10523]: [1B blob data]
Aug 17 11:10:31 zynthian startx[10523]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 17 11:10:32 zynthian startx[10523]: xinit: unexpected signal 15
Aug 17 11:10:32 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 11:10:32 zynthian systemd[1]: zynthian_debug.service: Failed with result 'timeout'.
Aug 17 11:10:32 zynthian systemd[1]: Stopped Zynthian User Interface (DEBUG).
Aug 17 11:10:32 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Aug 17 11:10:32 zynthian startx[10666]: X.Org X Server 1.20.4
Aug 17 11:10:32 zynthian startx[10666]: X Protocol Version 11, Revision 0
Aug 17 11:10:32 zynthian startx[10666]: Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
Aug 17 11:10:32 zynthian startx[10666]: Current Operating System: Linux zynthian 5.10.52-v7+ #1441 SMP Tue Aug 3 18:10:09 BST 2021 armv7l
Aug 17 11:10:32 zynthian startx[10666]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 17 11:10:32 zynthian startx[10666]: Build Date: 19 April 2021 03:23:36PM
Aug 17 11:10:32 zynthian startx[10666]: xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
Aug 17 11:10:32 zynthian startx[10666]: Current version of pixman: 0.36.0
Aug 17 11:10:32 zynthian startx[10666]: Before reporting problems, check http://wiki.x.org
Aug 17 11:10:32 zynthian startx[10666]: to make sure that you have the latest version.
Aug 17 11:10:32 zynthian startx[10666]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 17 11:10:32 zynthian startx[10666]: (++) from command line, (!!) notice, (II) informational,
Aug 17 11:10:32 zynthian startx[10666]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 17 11:10:32 zynthian startx[10666]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 17 11:10:32 2021
Aug 17 11:10:32 zynthian startx[10666]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 17 11:10:32 zynthian startx[10666]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 17 11:10:33 zynthian startx[10666]: /zynthian/config/img/fb_zynthian_boot.png is 320x240 PNG image, color type PALETTE, 8 bit
Aug 17 11:10:33 zynthian startx[10666]: Zooming image by 100%...done
Aug 17 11:10:33 zynthian startx[10666]: Merging...didn't find evidence of prior run.
Aug 17 11:10:33 zynthian startx[10666]: done
Aug 17 11:10:33 zynthian startx[10666]: Building XImage...done
Aug 17 11:10:34 zynthian startx[10666]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 17 11:10:34 zynthian startx[10666]: INFO:zynthian_gui_config.<module>: Wiring Layout PROTOTYPE-4
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.<module>: ZYNCODER A: [26, 25, 0, 4]
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.<module>: ZYNCODER B: [21, 27, 7, 3]
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.<module>: SWITCHES layout: [107, 23, 106, 2]
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 17 11:10:34 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 17 11:10:34 zynthian systemd[1]: Stopping Zynthian User Interface (DEBUG)...
Aug 17 11:10:34 zynthian startx[10666]: Terminated
Aug 17 11:10:35 zynthian startx[10666]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit
Aug 17 11:10:35 zynthian startx[10666]: Zooming image by 100%...done
Aug 17 11:10:35 zynthian startx[10666]: Merging...done
Aug 17 11:10:35 zynthian startx[10666]: Building XImage...done
Aug 17 11:10:38 zynthian startx[10666]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 17 11:10:38 zynthian startx[10666]: INFO:zynthian_gui_config.<module>: Wiring Layout PROTOTYPE-4
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.<module>: ZYNCODER A: [26, 25, 0, 4]
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.<module>: ZYNCODER B: [21, 27, 7, 3]
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.<module>: SWITCHES layout: [107, 23, 106, 2]
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 17 11:10:38 zynthian startx[10666]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 17 11:10:40 zynthian startx[10666]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 11:10:40 zynthian startx[10666]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Aug 17 11:10:40 zynthian startx[10666]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#simple> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Aug 17 11:10:40 zynthian startx[10666]: lilv_world_load_bundle(): warning: Ignoring bundle <file:///zynthian/zynthian-plugins/lv2/b_synth.lv2/>
Aug 17 11:10:40 zynthian startx[10666]: lilv_world_load_bundle(): note: Newer version of <http://gareus.org/oss/lv2/b_synth> loaded from <file:///zynthian/zynthian-plugins/lv2/b_synth/>
Aug 17 11:10:42 zynthian startx[10666]: Cannot connect to server socket err = No such file or directory
Aug 17 11:10:42 zynthian startx[10666]: Cannot connect to server request channel
Aug 17 11:10:42 zynthian startx[10666]: jack server is not running or cannot be started
Aug 17 11:10:42 zynthian startx[10666]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 11:10:42 zynthian startx[10666]: libzynseq failed to start jack client: 17
Aug 17 11:10:42 zynthian startx[10666]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Aug 17 11:10:42 zynthian startx[10666]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Aug 17 11:10:42 zynthian startx[10666]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Aug 17 11:10:42 zynthian startx[10666]: libjackpeak failed to start jack client: 17
Aug 17 11:10:42 zynthian startx[10666]: New instance of zynseq
Aug 17 11:10:42 zynthian startx[10666]: **zynseq initialising as zynthstep**
This is the pertinent bit
Check the jack config hasn’t been changed or gone missing.
@Gandalf , are you using the testing branch, as it’s explained here:
