V2 with lastest stable UI restarts every few seconds
Hi there,
I installed recent latest stable, used the same settings as before and now my UI is rebooting every few seconds.
What could it be?
Blockquote
Nov 16 00:40:32 zynthian systemd[1]: Started Zynthian User Interface.
Nov 16 00:40:32 zynthian startx[21909]: X.Org X Server 1.20.4
Nov 16 00:40:32 zynthian startx[21909]: X Protocol Version 11, Revision 0
Nov 16 00:40:32 zynthian startx[21909]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Nov 16 00:40:32 zynthian startx[21909]: Current Operating System: Linux zynthian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Nov 16 00:40:32 zynthian startx[21909]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:B4:0A:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo quiet splash vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Nov 16 00:40:32 zynthian startx[21909]: Build Date: 04 April 2023 07:50:56AM
Nov 16 00:40:32 zynthian startx[21909]: xorg-server 2:1.20.4-1+rpt4+deb10u9 (Debian -- User Support)
Nov 16 00:40:32 zynthian startx[21909]: Current version of pixman: 0.36.0
Nov 16 00:40:32 zynthian startx[21909]: Before reporting problems, check http://wiki.x.org
Nov 16 00:40:32 zynthian startx[21909]: to make sure that you have the latest version.
Nov 16 00:40:32 zynthian startx[21909]: Markers: (–) probed, (**) from config file, (==) default setting,
Nov 16 00:40:32 zynthian startx[21909]: (++) from command line, (!!) notice, (II) informational,
Nov 16 00:40:32 zynthian startx[21909]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Nov 16 00:40:32 zynthian startx[21909]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Nov 16 00:40:32 2023
Nov 16 00:40:32 zynthian startx[21909]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Nov 16 00:40:32 zynthian startx[21909]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Nov 16 00:40:33 zynthian startx[21909]: /zynthian/config/img/fb_zynthian_boot.png is 480x320 PNG image, color type GRAY, 8 bit
Nov 16 00:40:33 zynthian startx[21909]: Zooming image by 100%…done
Nov 16 00:40:33 zynthian startx[21909]: Merging…didn’t find evidence of prior run.
Nov 16 00:40:33 zynthian startx[21909]: done
Nov 16 00:40:33 zynthian startx[21909]: Building XImage…done
Nov 16 00:40:33 zynthian startx[21909]: ----------------------------------------------
Nov 16 00:40:33 zynthian startx[21909]: Linux Version: buster
Nov 16 00:40:33 zynthian startx[21909]: Kernel Version: 5.10.103-v7l+
Nov 16 00:40:33 zynthian startx[21909]: ZynthianOS Version: 2308
Nov 16 00:40:33 zynthian startx[21909]: Virtualization: none
Nov 16 00:40:33 zynthian startx[21909]: Hardware Architecture: armv7l
Nov 16 00:40:33 zynthian startx[21909]: Hardware Model: Raspberry Pi 4 Model B Rev 1.2
Nov 16 00:40:34 zynthian startx[21909]: ZynCore: Setting-up 8 x Zynswitches…
Nov 16 00:40:34 zynthian startx[21909]: ZynCore: Setting-up 4 x Zynpots (zyncoders)…
Nov 16 00:40:34 zynthian startx[21909]: Cannot connect to server socket err = No such file or directory
Nov 16 00:40:34 zynthian startx[21909]: Cannot connect to server request channel
Nov 16 00:40:34 zynthian startx[21909]: jackdmp 1.9.14
Nov 16 00:40:34 zynthian startx[21909]: Copyright 2001-2005 Paul Davis and others.
Nov 16 00:40:34 zynthian startx[21909]: Copyright 2004-2016 Grame.
Nov 16 00:40:34 zynthian startx[21909]: Copyright 2016-2019 Filipe Coelho.
Nov 16 00:40:34 zynthian startx[21909]: jackdmp comes with ABSOLUTELY NO WARRANTY
Nov 16 00:40:34 zynthian startx[21909]: This is free software, and you are welcome to redistribute it
Nov 16 00:40:34 zynthian startx[21909]: under certain conditions; see the file COPYING for details
Nov 16 00:40:34 zynthian startx[21909]: JACK server starting in realtime mode with priority 10
Nov 16 00:40:34 zynthian startx[21909]: self-connect-mode is “Don’t restrict self connect requests”
Nov 16 00:40:34 zynthian systemd[1]: Stopping Zynthian User Interface…
Nov 16 00:40:35 zynthian startx[21909]: creating alsa driver … hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
Nov 16 00:40:35 zynthian startx[21909]: ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
Nov 16 00:40:35 zynthian startx[21909]: configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
Nov 16 00:40:35 zynthian startx[21909]: ALSA: final selected sample format for playback: 16bit little-endian
Nov 16 00:40:35 zynthian startx[21909]: ALSA: use 2 periods for playback
Nov 16 00:40:37 zynthian startx[21909]: Started libzynmixer
Nov 16 00:40:37 zynthian startx[21909]: Started libzynseq
Nov 16 00:40:38 zynthian startx[21909]: Invalid card number.
Nov 16 00:40:38 zynthian startx[21909]: ERROR:zynthian_engine_alsa_mixer.get_mixer_zctrls: Command ‘amixer -M -c sndrpihifiberry’ returned non-zero exit status 1.
Nov 16 00:40:38 zynthian startx[21909]: libzynaudioplayer initialised
Nov 16 00:40:38 zynthian startx[21909]: Started libzynsmf
Nov 16 00:40:39 zynthian startx[21909]: JackGraphManager::Disconnect not connected port_src = 30 port_dst = 54
Nov 16 00:40:39 zynthian startx[21909]: Unknown destination port in attempted (dis)connection src_name [ttymidi:MIDI_in] dst_name [mod-host:midi_in]
Nov 16 00:40:39 zynthian startx[21909]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 59
Nov 16 00:40:39 zynthian startx[21909]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 60
Nov 16 00:40:39 zynthian startx[21909]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 59
Nov 16 00:40:41 zynthian startx[21909]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 74
Nov 16 00:40:44 zynthian startx[21909]: xinit: connection to X server lost
Nov 16 00:40:44 zynthian startx[21909]: [1B blob data]
Nov 16 00:40:44 zynthian startx[21909]: waiting for X server to shut down Jack main caught signal 15
Nov 16 00:40:44 zynthian startx[21909]: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server “:0”
Nov 16 00:40:44 zynthian startx[21909]: after 1785 requests (1771 known processed) with 0 events remaining.
Nov 16 00:40:44 zynthian startx[21909]: (II) Server terminated successfully (0). Closing log file.
Nov 16 00:40:45 zynthian startx[21909]: xinit: unexpected signal 15
Nov 16 00:40:45 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Nov 16 00:40:45 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Nov 16 00:40:45 zynthian systemd[1]: Stopped Zynthian User Interface.
Nov 16 00:40:45 zynthian systemd[1]: Started Zynthian User Interface.
Nov 16 00:40:45 zynthian startx[22230]: X.Org X Server 1.20.4
Nov 16 00:40:45 zynthian startx[22230]: X Protocol Version 11, Revision 0
Nov 16 00:40:45 zynthian startx[22230]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Nov 16 00:40:45 zynthian startx[22230]: Current Operating System: Linux zynthian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Nov 16 00:40:45 zynthian startx[22230]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:B4:0A:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo quiet splash vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Nov 16 00:40:45 zynthian startx[22230]: Build Date: 04 April 2023 07:50:56AM
Nov 16 00:40:45 zynthian startx[22230]: xorg-server 2:1.20.4-1+rpt4+deb10u9 (Debian -- User Support)
Nov 16 00:40:45 zynthian startx[22230]: Current version of pixman: 0.36.0
Nov 16 00:40:45 zynthian startx[22230]: Before reporting problems, check http://wiki.x.org
Nov 16 00:40:45 zynthian startx[22230]: to make sure that you have the latest version.
Nov 16 00:40:45 zynthian startx[22230]: Markers: (–) probed, (**) from config file, (==) default setting,
Nov 16 00:40:45 zynthian startx[22230]: (++) from command line, (!!) notice, (II) informational,
Nov 16 00:40:45 zynthian startx[22230]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Nov 16 00:40:45 zynthian startx[22230]: (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Nov 16 00:40:45 2023
Nov 16 00:40:45 zynthian startx[22230]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Nov 16 00:40:45 zynthian startx[22230]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Nov 16 00:40:46 zynthian startx[22230]: /zynthian/config/img/fb_zynthian_boot.png is 480x320 PNG image, color type GRAY, 8 bit
Nov 16 00:40:46 zynthian startx[22230]: Zooming image by 100%…done
Nov 16 00:40:46 zynthian startx[22230]: Merging…didn’t find evidence of prior run.
Nov 16 00:40:46 zynthian startx[22230]: done
Nov 16 00:40:46 zynthian startx[22230]: Building XImage…done
Nov 16 00:40:46 zynthian startx[22230]: ----------------------------------------------
Nov 16 00:40:46 zynthian startx[22230]: Linux Version: buster
Nov 16 00:40:46 zynthian startx[22230]: Kernel Version: 5.10.103-v7l+
Nov 16 00:40:46 zynthian startx[22230]: ZynthianOS Version: 2308
Nov 16 00:40:46 zynthian startx[22230]: Virtualization: none
Nov 16 00:40:46 zynthian startx[22230]: Hardware Architecture: armv7l
Nov 16 00:40:46 zynthian startx[22230]: Hardware Model: Raspberry Pi 4 Model B Rev 1.2
Nov 16 00:40:47 zynthian systemd[1]: Stopping Zynthian User Interface…
Nov 16 00:40:47 zynthian startx[22230]: ZynCore: Setting-up 8 x Zynswitches…
Nov 16 00:40:47 zynthian startx[22230]: ZynCore: Setting-up 4 x Zynpots (zyncoders)…
Nov 16 00:40:47 zynthian startx[22230]: Cannot connect to server socket err = No such file or directory
Nov 16 00:40:47 zynthian startx[22230]: Cannot connect to server request channel
Nov 16 00:40:47 zynthian startx[22230]: jackdmp 1.9.14
Nov 16 00:40:47 zynthian startx[22230]: Copyright 2001-2005 Paul Davis and others.
Nov 16 00:40:47 zynthian startx[22230]: Copyright 2004-2016 Grame.
Nov 16 00:40:47 zynthian startx[22230]: Copyright 2016-2019 Filipe Coelho.
Nov 16 00:40:47 zynthian startx[22230]: jackdmp comes with ABSOLUTELY NO WARRANTY
Nov 16 00:40:47 zynthian startx[22230]: This is free software, and you are welcome to redistribute it
Nov 16 00:40:47 zynthian startx[22230]: under certain conditions; see the file COPYING for details
Nov 16 00:40:47 zynthian startx[22230]: JACK server starting in realtime mode with priority 10
Nov 16 00:40:47 zynthian startx[22230]: self-connect-mode is “Don’t restrict self connect requests”
Nov 16 00:40:48 zynthian startx[22230]: creating alsa driver … hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
Nov 16 00:40:48 zynthian startx[22230]: ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
Nov 16 00:40:48 zynthian startx[22230]: configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
Nov 16 00:40:48 zynthian startx[22230]: ALSA: final selected sample format for playback: 16bit little-endian
Nov 16 00:40:48 zynthian startx[22230]: ALSA: use 2 periods for playback
Nov 16 00:40:51 zynthian startx[22230]: Started libzynmixer
Nov 16 00:40:51 zynthian startx[22230]: Started libzynseq
Nov 16 00:40:51 zynthian startx[22230]: Invalid card number.
Nov 16 00:40:51 zynthian startx[22230]: ERROR:zynthian_engine_alsa_mixer.get_mixer_zctrls: Command ‘amixer -M -c sndrpihifiberry’ returned non-zero exit status 1.
Nov 16 00:40:52 zynthian startx[22230]: libzynaudioplayer initialised
Nov 16 00:40:52 zynthian startx[22230]: Started libzynsmf
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 30 port_dst = 54
Nov 16 00:40:52 zynthian startx[22230]: Unknown destination port in attempted (dis)connection src_name [a2j:Midi Through [14] (capture): Midi Through Port-0] dst_name [mod-host:midi_in]
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 59
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 60
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 59
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 60
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 61
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 62
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 61
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 62
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 63
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 64
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 63
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 64
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 65
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 66
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 65
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 66
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 67
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 68
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 67
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 68
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 69
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 70
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 69
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 70
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 71
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 72
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 71
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 72
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 73
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 74
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 73
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 74
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 75
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 76
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 75
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 76
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 77
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 78
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 77
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 78
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 79
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 80
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 79
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 80
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 81
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 82
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 81
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 82
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 83
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 84
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 83
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 84
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 85
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 86
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 85
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 86
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 87
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 88
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 87
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 88
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 89
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 90
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 89
Nov 16 00:40:52 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 90
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 53 port_dst = 31
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 100 port_dst = 49
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 105 port_dst = 48
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 25 port_dst = 106
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 27 port_dst = 51
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 29 port_dst = 99
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 30 port_dst = 54
Nov 16 00:40:54 zynthian startx[22230]: Unknown destination port in attempted (dis)connection src_name [a2j:Midi Through [14] (capture): Midi Through Port-0] dst_name [mod-host:midi_in]
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 101 port_dst = 91
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Connect already connected port_src = 95 port_dst = 1
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 59
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 60
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 59
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 60
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 61
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 62
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 61
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 62
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 63
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 64
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 63
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 64
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 65
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 66
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 65
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 66
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 67
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 68
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 67
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 68
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 69
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 70
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 69
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 70
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 71
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 72
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 71
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 72
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 73
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 74
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 73
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 74
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 75
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 76
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 75
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 76
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 77
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 78
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 77
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 78
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 79
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 80
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 79
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 80
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 81
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 82
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 81
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 82
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 83
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 84
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 83
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 84
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 85
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 86
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 85
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 86
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 87
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 88
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 87
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 88
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 89
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 97 port_dst = 90
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 89
Nov 16 00:40:54 zynthian startx[22230]: JackGraphManager::Disconnect not connected port_src = 98 port_dst = 90
Nov 16 00:40:57 zynthian startx[22230]: Jack main caught signal 15
Nov 16 00:40:57 zynthian startx[22230]: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server “:0”
Nov 16 00:40:57 zynthian startx[22230]: xinit: after 1566 requests (1351 known processed) with 0 events remaining.
Nov 16 00:40:57 zynthian startx[22230]: connection to X server lost
Nov 16 00:40:57 zynthian startx[22230]: [1B blob data]
Nov 16 00:40:57 zynthian startx[22230]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Nov 16 00:40:58 zynthian startx[22230]: xinit: unexpected signal 15
Nov 16 00:40:58 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Nov 16 00:40:58 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Nov 16 00:40:58 zynthian systemd[1]: Stopped Zynthian User Interface.
Blockquote
Something goes wrong with your audio configuration.
Are you configuring sample rate of 48KHz? Could you try with the default 44.1KHz?
Anyway, this doesn’t look as a V2. AFAIK, Zynthian V2 kits doesn’t have audio input :wink:
You are using a numerical (card number) index for the audio hardware device: hw:0. This relies upon the soundcard being the first detected audio or MIDI device. If you plug in other devices, e.g. USB MIDI controller then this may fail. It can also fail if there are other hardware devices such as HDMI (like the RPi4 you are using). You should use the name of the soundcard in the jack config, e.g. hw:sndrpihifiberry.
@riban is right!
Anyway, before trying a customized configuration, you could try with some of the “standard” ones from the webconf list.
hi there. of course you are right. im not using v2 since i upgraded to hifiberry dac plus adc and rpi4. im using settings for hifiberry dac adc
-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X raw
as jack settings in the webconf and no custom one.
when sshing the rpi i wont find the hifiberry in alsamixer? this makes me suspicious whether it is even recognized? i didnt change that hardware and i used it with same hardware configuration with the old system…
