Hi @uhoh7 !
Kit v4 works with the latest stable out-the box. It shouldn’t be needed any extra config, so it seems there is something wrong with your build or some of the parts.
Please, open the case and double-check everything carefully. Take some detailed photos so we can verify there is nothing “strange”.
Regarding your logs, everything seems to be working OK:
Restarting UI in debug mode
-- Logs begin at Wed 2023-02-08 06:50:14 GMT. --
Feb 09 18:13:37 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Feb 09 18:13:37 zynthian startx[1661]: X.Org X Server 1.20.4
Feb 09 18:13:37 zynthian startx[1661]: X Protocol Version 11, Revision 0
Feb 09 18:13:37 zynthian startx[1661]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Feb 09 18:13:37 zynthian startx[1661]: Current Operating System: Linux zynthian 5.15.70-v7l+ #1590 SMP Tue Sep 27 15:58:00 BST 2022 armv7l
Feb 09 18:13:37 zynthian startx[1661]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:E7:30:6A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Feb 09 18:13:37 zynthian startx[1661]: Build Date: 04 August 2022 12:56:42PM
Feb 09 18:13:37 zynthian startx[1661]: xorg-server 2:1.20.4-1+rpt4+deb10u5 (https://www.debian.org/support)
Feb 09 18:13:37 zynthian startx[1661]: Current version of pixman: 0.36.0
Feb 09 18:13:37 zynthian startx[1661]: Before reporting problems, check http://wiki.x.org
Feb 09 18:13:37 zynthian startx[1661]: to make sure that you have the latest version.
Feb 09 18:13:37 zynthian startx[1661]: Markers: (--) probed, (**) from config file, (==) default setting,
Feb 09 18:13:37 zynthian startx[1661]: (++) from command line, (!!) notice, (II) informational,
Feb 09 18:13:37 zynthian startx[1661]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 09 18:13:37 zynthian startx[1661]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb 9 18:13:37 2023
Feb 09 18:13:37 zynthian startx[1661]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Feb 09 18:13:37 zynthian startx[1661]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Feb 09 18:13:38 zynthian startx[1661]: /zynthian/config/img/fb_zynthian_boot.png is 480x320 PNG image, color type GRAY, 8 bit
Feb 09 18:13:38 zynthian startx[1661]: Zooming image by 100%...done
Feb 09 18:13:38 zynthian startx[1661]: Merging...didn't find evidence of prior run.
Feb 09 18:13:38 zynthian startx[1661]: done
Feb 09 18:13:38 zynthian startx[1661]: Building XImage...done
Feb 09 18:13:38 zynthian startx[1661]: ----------------------------------------------
Feb 09 18:13:38 zynthian startx[1661]: Linux Version: buster
Feb 09 18:13:38 zynthian startx[1661]: Kernel Version: 5.15.70-v7l+
Feb 09 18:13:38 zynthian startx[1661]: ZynthianOS Version: 2211
Feb 09 18:13:38 zynthian startx[1661]: Virtualization: none
Feb 09 18:13:38 zynthian startx[1661]: Hardware Architecture: armv7l
Feb 09 18:13:38 zynthian startx[1661]: Hardware Model: Raspberry Pi 4 Model B Rev 1.5
Feb 09 18:13:38 zynthian startx[1661]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Feb 09 18:13:38 zynthian startx[1661]: INFO:zynthian_gui_config.<module>: Wiring Layout MCP23017_ZynScreen
Feb 09 18:13:39 zynthian startx[1661]: ZynCore: Setting-up 8 x Zynswitches...
Feb 09 18:13:39 zynthian startx[1661]: ZynCore: Setting-up 4 x Zynpots (zyncoders)...
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out', 'QmidiNet:in_1']
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Feb 09 18:13:40 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Feb 09 18:13:41 zynthian startx[1661]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Feb 09 18:13:41 zynthian startx[1661]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Feb 09 18:13:41 zynthian startx[1661]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Feb 09 18:13:41 zynthian startx[1661]: INFO:zynthian_gui.zynswitches_init: INIT 8 ZYNSWITCHES ...
Feb 09 18:13:41 zynthian startx[1661]: INFO:zynthian_gui.zynswitches_midi_setup: CUSTOM I/O SETUP...
Feb 09 18:13:41 zynthian startx[1661]: Started libzynmixer
Feb 09 18:13:41 zynthian startx[1661]: Started libzynseq
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer.get_controllers_dict: MIXER CTRL LIST: ['Digital Left', 'PGA Gain Left', 'Digital Right', 'PGA Gain Right', 'ADC Left Input', 'ADC Left', 'ADC Right Input', 'ADC Right']
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: ADC_0 => 9
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: ADC_1 => 9
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Digital_0 => 100
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Digital_1 => 100
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'Digital' 'Playback' 100%,100% unmute
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'PGA Gain Left' '0.0dB'
Feb 09 18:13:42 zynthian startx[1661]: INFO:zynthian_gui_admin.stop_rbpi_headphones: STOPPING RBPI HEADPHONES
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'PGA Gain Right' '0.0dB'
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'ADC Left Input' 'VINL1[SE]'
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'ADC' 'Capture' 9%,9% unmute
Feb 09 18:13:42 zynthian startx[1661]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'ADC Right Input' 'VINR1[SE]'
Feb 09 18:13:43 zynthian startx[1661]: Started libzynsmf
Feb 09 18:13:43 zynthian startx[1661]: INFO:zynthian_gui_midi_recorder.__init__: midi recorder created
Feb 09 18:13:43 zynthian startx[1661]: INFO:zynthian_gui_patterneditor.load_keymap: MIDI channel 0 seems empty.
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_controller.config: ZCTRL 'CTRL#0': 0 (-100 -> 100), None, None
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_controller.config: ZCTRL 'CTRL#1': 0 (-100 -> 100), None, None
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_controller.config: ZCTRL 'CTRL#2': 0 (-100 -> 100), None, None
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_controller.config: ZCTRL 'CTRL#3': 0 (-100 -> 100), None, None
Feb 09 18:13:43 zynthian startx[1661]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_controller.config: ZCTRL 'Layer': 0 (0 -> 0), None, None
Feb 09 18:13:43 zynthian startx[1661]: INFO:zynthian_gui_layer.load_snapshot: Loading snapshot /zynthian/zynthian-my-data/snapshots/last_state.zss =>
Feb 09 18:13:43 zynthian startx[1661]: {"index": 0, "mixer": {"chan_00": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_01": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_02": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_03": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_04": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_05": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_06": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_07": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_08": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_09": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_10": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_11": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_12": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_13": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_14": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_15": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "chan_16": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}, "main": {"level": {"value": 0.800000011920929}, "balance": {"value": 0.0}, "mute": {"value": 0}, "solo": {"value": 0}, "mono": {"value": 0}, "phase": {"value": 0}}}, "layers": [{"engine_name": "Audio Input", "engine_nick": "AI", "engine_jackname": "audioin-256", "midi_chan": 256, "bank_index": 0, "bank_name": null, "bank_info": null, "preset_index": 0, "preset_name": null, "preset_info": null, "show_fav_presets": false, "controllers_dict": {}, "current_screen_index": -1}, {"engine_name": "Audio Levels", "engine_nick": "MX", "engine_jackname": "", "midi_chan": null, "bank_index": 0, "bank_name": null, "bank_info": null, "preset_index": 0, "preset_name": null, "preset_info": null, "show_fav_presets": false, "controllers_dict": {"Digital_0": {"value": 100}, "PGA_Gain_Left": {"value": 24}, "Digital_1": {"value": 100}, "PGA_Gain_Right": {"value": 24}, "ADC_Left_Input": {"value": 1}, "ADC_0": {"value": 9}, "ADC_Right_Input": {"value": 1}, "ADC_1": {"value": 9}}, "current_screen_index": 0}], "clone": [[{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}]], "note_range": [{"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}, {"note_low": 0, "note_high": 127, "octave_trans": 0, "halftone_trans": 0}], "audio_capture": {"audioin-256": ["zynmixer:send_a", "zynmixer:send_b"]}, "last_snapshot_fpath": "/zynthian/zynthian-my-data/snapshots/last_state.zss", "audio_recorder_armed": [], "extended_config": {"MX": null, "AI": null}, "midi_profile_state": {"MASTER_BANK_CHANGE_UP": "", "SYS_ENABLED": "1", "MASTER_PROGRAM_CHANGE_DOWN": "", "SINGLE_ACTIVE_CHANNEL": "1", "RTPMIDI_ENABLED": "0", "TOUCHOSC_ENABLED": "1", "PORTS": "DISABLED_IN=\\nENABLED_OUT=ttymidi:MIDI_out,QmidiNet:in_1\\nENABLED_FB=", "MASTER_CHANNEL": "0", "NETWORK_ENABLED": "0", "FILTER_RULES": "", "PROG_CHANGE_ZS3": "1", "MASTER_PROGRAM_CHANGE_UP": "", "BANK_CHANGE": "0", "CC_AUTOMODE": "0", "MASTER_BANK_CHANGE_CCNUM": "0", "MASTER_BANK_CHANGE_DOWN": "", "PRESET_PRELOAD_NOTEON": "1", "AUBIONOTES_ENABLED": "0", "FINE_TUNING": "440", "MASTER_PROGRAM_CHANGE_TYPE": "Custom", "PLAY_LOOP": "0", "FILTER_OUTPUT": "0"}, "audio_routing": {"audioin-256": ["mixer"]}, "midi_routing": {"audioin-256": ["MIDI-OUT", "NET-OUT"]}, "learned_zs3": [], "zynseq_riff_b64": "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"}
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_layer.remove_all_layers: Remove layer 0 => Main#Audio Input ...
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_engine.stop_unused_engines: Stopping Unused Engine 'AI/1' ...
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out', 'QmidiNet:in_1']
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Feb 09 18:13:43 zynthian startx[1661]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Feb 09 18:13:43 zynthian startx[1661]: INFO:zynthian_gui_admin.stop_rtpmidi: STOPPING RTP-MIDI
Feb 09 18:13:43 zynthian startx[1661]: INFO:zynthian_gui_admin.stop_qmidinet: STOPPING QMIDINET
Feb 09 18:13:44 zynthian startx[1661]: INFO:zynthian_gui_admin.start_touchosc2midi: STARTING touchosc2midi
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_gui_admin.stop_aubionotes: STOPPING aubionotes
Feb 09 18:13:45 zynthian startx[1661]: DEBUG:zynthian_layer.load_bank_list: BANK LIST =>
Feb 09 18:13:45 zynthian startx[1661]: []
Feb 09 18:13:45 zynthian startx[1661]: DEBUG:zynthian_layer.load_bank_list: BANK MSB INFO =>
Feb 09 18:13:45 zynthian startx[1661]: [[0, 0], [0, 0], [0, 0]]
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 0 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 1 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 2 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 3 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 4 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 5 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 6 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 7 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 8 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 9 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 10 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 11 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 12 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 13 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 14 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 15 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_audio_recorder.unarm: Channel 256 not armed
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynthian_gui_layer.restore_state_snapshot: Setting curlayer to 0
Feb 09 18:13:45 zynthian startx[1661]: INFO:zynseq.restore_riff_data: Restoring RIFF data...
Perhaps the display is not connected correctly. Put extra attention to it and take photos as detailed as possible.
Kind Regards,
