V5.1 Kit: Replacement SD ribbon cable
Hey,
Just picked up my 5.1 kit and put it together a few days ago. I couldn’t get the system to boot. I decided too try inserting the micro sd directly to the pi and it booted with no bother. I have re-inserted the ribbon cable a few times and retried to no avail. I was wondering where I could go about getting a replacement cable from as mine may well be broken. Too harsh of a bend? Not sure.
Is there anything else I could try to eliminate possible issues? It seems pretty cut and dry to me but I’m no expert. I’m using a 256gb card if that matters and as I said, it boots fine if its inserted directly to the pi
Hi Thom!
Welcome to zynthianland!
I will send you a replacement ASAP.
Please, send me a picture from the “broken” cable, i would like to know how it broke and try to find solutions for the future.
That’s incredible, thank you!
Where would you like me to send the picture to?
Hey! Just wanted to resurrect this thread because I suddenly am having an issue with my SD card slot.
Everything was working fine for the past several months, but I hadn’t plugged my Zynthian in for a couple of weeks. When I went to boot it up today, it just hangs and the screen never shows anything. I opened it up and tried a bunch of things before finally figuring out that the SD slot is no longer working with extension cable. If I put the fully functional SD I’ve been using for months directly in the Pi, it runs fine. I am not sure if it’s a failed ribbon cable, but I’m crossing my fingers since I hope it’s not an issue with the slot itself on the PCB.
Anyways, I would love to start by replacing the ribbon cable first, but I can’t find any info on the 10 pin SD extension anywhere. Help?
Hi @ekosnar !
I will ship a replacement ASAP.
What SD card, brand, model and size are you currently using?
Have you tried to remove the plastic bumps from the connector as described here?
https://wiki.zynthian.org/index.php/Assembling_Zynthian_Kit_V5.1#V5_KITS_SOLD_BEFORE_2025-06-01_-_Fixing_FFC_connectors
Hey!
Thank you! No, I hadn’t seen this, since I had assembled before the issue was noticed. I do have the bumps on those connectors so I will get them removed, however, my SD ribbon did come unsoldered at the SD part, since I was probably being a bit rough trying to reseat things. I’m comfy with a soldering gun, but not able to fix this in its current state.
Thanks for sending a replacement though! I appreciate it!
Don’t forget to tell me the shipping address by PM.
Hi @jofemodo , I also broke my SD cable building 5.1, I mailed to Susanna and she sent a new cable, thanks for the wonderful support. I attach the image of the broken cable for reference, maybe is too short and the 90° rotation can broke a contact line.
Now my Z5.1 is in perfect working shape, and as I said elsewhere is my Definitive portable synth for my music. First Keyboard master/Pianoteq or Rhodes MK V trough Neural amp modeller + Reveb and Chorus/flanger, second Key Dexed, Ostirus, or other for pad/solo/ecc.). When I go playing I bring only Z5.1 and connect whatever keyboard I find.
Hi, I was wondering if there is a way to get a replacement cable from aliexpress, amazon, or any other online retailer? I have a bent cable that was pinched when I first put the kit together earlier this year and because of the sensetivity and lack of decent tweezers, it hasn’t ever worked.
Recently I’ve had to open the box a few times to access and re-write the sd card to try vangelis. This hasn’t really been a blocker for using the device, because I’ve barely used it, but I would like to know how to fix this because the random similar-looking sdhc-extender cables I’ve gotten from amazon have the wrong number of conductors on the cable, so don’t work as a plug-in replacement.
Hi @pcn !
Please, could you be more specific about the cable you need? Do you mean the SD-card extender cable?
Confirm and tell me you address by PM and i will send you some units by by mail.
The best!
