Vangelis does not start with HDMI screen only
I have the latest Vangelis Beta (trixie) running on a custom made Zynthian with a RPI4:
Raspberry Pi 4 Model B Rev 1.1
Audio: HifiBerry DAC+ ADC PRO
Display: Pi 7 Touchscreen Display 800x480
Wiring: MCP23017_ZynScreen
I2C: MCP23017@0x20, MCP23017@0x21
Profile: v4_stage
I wanted to test this with a RPI5, but unfortunatley the DSI cable does not fit. Therefore I hooked up a Joy-IT RB LCD10-2 HDMI screen on a second system:
Raspberry Pi 5 Model B Rev 1.0
Display: Generic HDMI/DSI Display
Profile: v4_stage
After starting with a fresh Vangelis Beta image, I only see the booting up and a login. Nothing more. Also the webconf does not become available, so there is nog way to change settings.
Thereafter I made a second SD card with the latest stable on it (ORAM) and that works fine.
The trusted screens pop up and also webconf is avalable.
First of all, update Zynthian and reboot. This should fix the issue.
If that does not work, open Terminal from webconf, enter and run:
sudo apt install gldriver-test
After reboot it should work.
The problem was that only port 22 was open, so I could not reach webconf.
Well, long story short, after having loaded Vangelis on the SD card for the sixth time, I could reach webconf, but I still had to do the gldriver-test install in order to get the proper screen.
I never before had to do that.
Thanks for the help.
It’s a Beta, not a final release :wink:
The Beta2 will work better for sure …
