Thanks @riban,
As it was a new custom build I thought it was my fault setting up my unofficial hardware.
I captured the log just when failing. I hope this will help you to manage the issue.
BTW, Vangelis is a nice work.
Best regards.
(venv) root@zynthian:/zynthian/zynthian-my-data/scripts# journalctl -u zynthian -n 200 --no-pager
Apr 19 19:42:19 zynthian startx[52699]: Hardware Model: Raspberry Pi 5 Model B Rev 1.1
Apr 19 19:42:19 zynthian startx[52699]: ----------------------------------------------
Apr 19 19:42:19 zynthian startx[52728]: Generating splash images for display resolution 1920 x 1280…
Apr 19 19:42:19 zynthian startx[52748]: /zynthian/config/img/fb_zynthian_boot.jpg is a 1920x1280 JPEG image, color space Grayscale, 1 comp, Huffman coding.
Apr 19 19:42:19 zynthian startx[52748]: Zooming image by 100%…done
Apr 19 19:42:19 zynthian startx[52748]: Merging…didn’t find evidence of prior run.
Apr 19 19:42:19 zynthian startx[52748]: done
Apr 19 19:42:19 zynthian startx[52748]: Building XImage…done
Apr 19 19:42:20 zynthian startx[52749]: Loaded libzynaudioplayer using libsndfile-1.2.0
Apr 19 19:42:21 zynthian startx[52749]: Started zynmixer_chan
Apr 19 19:42:21 zynthian startx[52749]: Started zynmixer_bus
Apr 19 19:42:21 zynthian startx[52749]: Started libzynseq
Apr 19 19:42:21 zynthian startx[52749]: Started libzynsmf
Apr 19 19:42:25 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 1, delay: 930.0us
Apr 19 19:42:25 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 2, delay: 37926.0us
Apr 19 19:42:56 zynthian startx[52749]: WARNING:zynthian_gui.busy_thread_task: Clients have been busy for longer than 30s: {‘add_processor’, ‘load snapshot’, ‘set_chain_state’, ‘ui startup’}
Apr 19 19:43:30 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 3, delay: 2893.0us
Apr 19 19:43:30 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 4, delay: 591.0us
Apr 19 19:43:30 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 5, delay: 1102.0us
Apr 19 19:43:30 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 6, delay: 1244.0us
Apr 19 19:43:30 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 7, delay: 327.0us
Apr 19 19:43:31 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 8, delay: 788.0us
Apr 19 19:43:32 zynthian startx[52749]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 9, delay: 97565.0us
Apr 19 19:43:56 zynthian systemd[1]: Stopping zynthian.service - Zynthian User Interface…
Apr 19 19:44:04 zynthian startx[52749]: ERROR:zynthian_chain_manager.remove_processor: Chain None doesn’t exist!
Apr 19 19:44:04 zynthian startx[52749]: zynmixer ended
Apr 19 19:44:04 zynthian startx[52749]: free(): invalid pointer
Apr 19 19:44:04 zynthian startx[52699]: ./zynthian.sh: line 316: 52749 Aborted ./zynthian_main.py
Apr 19 19:44:04 zynthian startx[52699]: *******************
Apr 19 19:44:04 zynthian startx[52699]: EXIT STATUS => 134
Apr 19 19:44:04 zynthian startx[52664]: xinit: connection to X server lost
Apr 19 19:44:04 zynthian startx[52664]: waiting for X server to shut down
Apr 19 19:44:04 zynthian startx[52665]: (II) Server terminated successfully (0). Closing log file.
Apr 19 19:44:05 zynthian startx[52664]: xinit: unexpected signal 15
Apr 19 19:44:05 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Apr 19 19:44:05 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Apr 19 19:44:05 zynthian systemd[1]: Stopped zynthian.service - Zynthian User Interface.
Apr 19 19:44:05 zynthian systemd[1]: zynthian.service: Consumed 2min 9ms CPU time.
Apr 19 19:44:05 zynthian systemd[1]: Started zynthian.service - Zynthian User Interface.
Apr 19 19:44:05 zynthian startx[53638]: X.Org X Server 1.21.1.7
Apr 19 19:44:05 zynthian startx[53638]: X Protocol Version 11, Revision 0
Apr 19 19:44:05 zynthian startx[53638]: Current Operating System: Linux zynthian 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16) aarch64
Apr 19 19:44:05 zynthian startx[53638]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=88:A2:9E:0A:F9:9F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait console=tty1 logo.nologo modules-load=dwc2,libcomposite
Apr 19 19:44:05 zynthian startx[53638]: xorg-server 2:21.1.7-3+rpt3+deb12u11 ( Debian -- User Support )
Apr 19 19:44:05 zynthian startx[53638]: Current version of pixman: 0.44.0
Apr 19 19:44:05 zynthian startx[53638]: Before reporting problems, check http://wiki.x.org
Apr 19 19:44:05 zynthian startx[53638]: to make sure that you have the latest version.
Apr 19 19:44:05 zynthian startx[53638]: Markers: (–) probed, () from config file, (==) default setting,
Apr 19 19:44:05 zynthian startx[53638]: (++) from command line, (!!) notice, (II) informational,
Apr 19 19:44:05 zynthian startx[53638]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Apr 19 19:44:05 zynthian startx[53638]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Apr 19 19:44:05 2026
Apr 19 19:44:05 zynthian startx[53638]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Apr 19 19:44:05 zynthian startx[53638]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Apr 19 19:44:06 zynthian startx[53650]: ----------------------------------------------
Apr 19 19:44:06 zynthian startx[53650]: Linux Version: bookworm
Apr 19 19:44:06 zynthian startx[53650]: Kernel Version: 6.12.47+rpt-rpi-2712
Apr 19 19:44:06 zynthian startx[53650]: ZynthianOS Version: 2601
Apr 19 19:44:06 zynthian startx[53650]: Virtualization: none
Apr 19 19:44:06 zynthian startx[53650]: Hardware Architecture: aarch64
Apr 19 19:44:06 zynthian startx[53650]: Hardware Model: Raspberry Pi 5 Model B Rev 1.1
Apr 19 19:44:06 zynthian startx[53679]: /zynthian/config/img/fb_zynthian_boot.jpg is a 1920x1280 JPEG image, color space Grayscale, 1 comp, Huffman coding.
Apr 19 19:44:06 zynthian startx[53679]: Zooming image by 100%…done
Apr 19 19:44:06 zynthian startx[53679]: Merging…didn’t find evidence of prior run.
Apr 19 19:44:06 zynthian startx[53679]: done
Apr 19 19:44:06 zynthian startx[53679]: Building XImage…done
Apr 19 19:44:07 zynthian startx[53681]: Loaded libzynaudioplayer using libsndfile-1.2.0
Apr 19 19:44:07 zynthian startx[53681]: Started zynmixer_chan
Apr 19 19:44:07 zynthian startx[53681]: Started zynmixer_bus
Apr 19 19:44:07 zynthian startx[53681]: Started libzynseq
Apr 19 19:44:07 zynthian startx[53681]: Started libzynsmf
Apr 19 19:44:07 zynthian startx[53681]: ERROR:zynthian_state_manager.save_snapshot: Traceback (most recent call last):
Apr 19 19:44:07 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 1065, in save_snapshot
Apr 19 19:44:07 zynthian startx[53681]: state = self.get_state()
Apr 19 19:44:07 zynthian startx[53681]: ^^^^^^^^^^^^^^^^
Apr 19 19:44:07 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 966, in get_state
Apr 19 19:44:07 zynthian startx[53681]: self.save_zs3(“zs3-0”, “Last state”)
Apr 19 19:44:07 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 1616, in save_zs3
Apr 19 19:44:07 zynthian startx[53681]: “active_chain”: self.chain_manager.active_chain.chain_id,
Apr 19 19:44:07 zynthian startx[53681]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Apr 19 19:44:07 zynthian startx[53681]: AttributeError: ‘NoneType’ object has no attribute ‘chain_id’
Apr 19 19:44:07 zynthian startx[53681]: Traceback (most recent call last):
Apr 19 19:44:07 zynthian startx[53681]: ERROR:zynthian_state_manager.save_snapshot: Can’t save snapshot file ‘/zynthian/zynthian-my-data/snapshots/last_state.zss’: ‘NoneType’ object has no attribute ‘chain_id’
Apr 19 19:44:10 zynthian startx[53681]: ERROR:zynthian_state_manager.load_snapshot: Invalid snapshot: ‘zynthian_state_manager’ object has no attribute ‘main_mixbus_proc’
Apr 19 19:44:10 zynthian startx[53681]: Traceback (most recent call last):
Apr 19 19:44:10 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 1120, in load_snapshot
Apr 19 19:44:10 zynthian startx[53681]: self.mute(True)
Apr 19 19:44:10 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 353, in mute
Apr 19 19:44:10 zynthian startx[53681]: self.main_mixbus_proc.controllers_dict[“mute”].set_value(mute)
Apr 19 19:44:10 zynthian startx[53681]: ^^^^^^^^^^^^^^^^^^^^^
Apr 19 19:44:10 zynthian startx[53681]: AttributeError: ‘zynthian_state_manager’ object has no attribute ‘main_mixbus_proc’
Apr 19 19:44:12 zynthian startx[53681]: Traceback (most recent call last):
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/./zynthian_main.py”, line 47, in
Apr 19 19:44:12 zynthian startx[53681]: zynthian_gui_config.zyngui = zyngui = zynthian_gui()
Apr 19 19:44:12 zynthian startx[53681]: ^^^^^^^^^^^^^^
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngui/zynthian_gui.py”, line 166, in init
Apr 19 19:44:12 zynthian startx[53681]: self.state_manager = zynthian_state_manager()
Apr 19 19:44:12 zynthian startx[53681]: ^^^^^^^^^^^^^^^^^^^^^^^^
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 191, in init
Apr 19 19:44:12 zynthian startx[53681]: self.start()
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 232, in start
Apr 19 19:44:12 zynthian startx[53681]: self.default_vncserver()
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 2428, in default_vncserver
Apr 19 19:44:12 zynthian startx[53681]: self.stop_vncserver(False)
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 2413, in stop_vncserver
Apr 19 19:44:12 zynthian startx[53681]: self.load_last_state_snapshot()
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 1320, in load_last_state_snapshot
Apr 19 19:44:12 zynthian startx[53681]: return self.load_snapshot(self.last_state_snapshot_fpath)
Apr 19 19:44:12 zynthian startx[53681]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 1247, in load_snapshot
Apr 19 19:44:12 zynthian startx[53681]: self.mute(mute, 0)
Apr 19 19:44:12 zynthian startx[53681]: File “/zynthian/zynthian-ui/zyngine/zynthian_state_manager.py”, line 353, in mute
Apr 19 19:44:12 zynthian startx[53681]: self.main_mixbus_proc.controllers_dict[“mute”].set_value(mute)
Apr 19 19:44:12 zynthian startx[53681]: AttributeError: ‘zynthian_state_manager’ object has no attribute ‘main_mixbus_proc’
Apr 19 19:44:12 zynthian startx[53681]: zynmixer ended
Apr 19 19:44:12 zynthian startx[53681]: libzynaudioplayer exiting
Apr 19 19:44:12 zynthian startx[53650]: *******************
Apr 19 19:44:12 zynthian startx[53650]: EXIT STATUS => 1
Apr 19 19:44:12 zynthian startx[53737]: /zynthian/config/img/fb_zynthian_message.jpg is a 1920x1280 JPEG image, color space YCbCr, 3 comps, Huffman coding.
Apr 19 19:44:12 zynthian startx[53737]: Zooming image by 100%…done
Apr 19 19:44:12 zynthian startx[53737]: Merging…done
Apr 19 19:44:12 zynthian startx[53737]: Building XImage…done
Apr 19 19:44:23 zynthian startx[53742]: Loaded libzynaudioplayer using libsndfile-1.2.0
Apr 19 19:44:24 zynthian startx[53742]: Started zynmixer_chan
Apr 19 19:44:24 zynthian startx[53742]: Started zynmixer_bus
Apr 19 19:44:24 zynthian startx[53742]: Started libzynseq
Apr 19 19:44:24 zynthian startx[53742]: Started libzynsmf
Apr 19 19:45:47 zynthian systemd[1]: Stopping zynthian.service - Zynthian User Interface…
Apr 19 19:45:48 zynthian startx[53742]: ERROR:zynthian_chain_manager.remove_processor: Chain None doesn’t exist!
Apr 19 19:45:48 zynthian startx[53742]: zynmixer ended
Apr 19 19:45:49 zynthian startx[53742]: zynmixer ended
Apr 19 19:45:49 zynthian startx[53742]: libzynaudioplayer exiting
Apr 19 19:45:49 zynthian startx[53650]: *******************
Apr 19 19:45:49 zynthian startx[53650]: EXIT STATUS => 101
Apr 19 19:45:49 zynthian startx[53637]: xinit: connection to X server lost
Apr 19 19:45:49 zynthian startx[53637]: waiting for X server to shut down
Apr 19 19:45:49 zynthian startx[53638]: (II) Server terminated successfully (0). Closing log file.
Apr 19 19:45:50 zynthian startx[53637]: xinit: unexpected signal 15
Apr 19 19:45:50 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Apr 19 19:45:50 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Apr 19 19:45:50 zynthian systemd[1]: Stopped zynthian.service - Zynthian User Interface.
Apr 19 19:45:50 zynthian systemd[1]: zynthian.service: Consumed 9.171s CPU time.
Apr 19 19:45:50 zynthian systemd[1]: Started zynthian.service - Zynthian User Interface.
Apr 19 19:45:50 zynthian startx[54042]: X.Org X Server 1.21.1.7
Apr 19 19:45:50 zynthian startx[54042]: X Protocol Version 11, Revision 0
Apr 19 19:45:50 zynthian startx[54042]: Current Operating System: Linux zynthian 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16) aarch64
Apr 19 19:45:50 zynthian startx[54042]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=88:A2:9E:0A:F9:9F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait console=tty1 logo.nologo modules-load=dwc2,libcomposite
Apr 19 19:45:50 zynthian startx[54042]: xorg-server 2:21.1.7-3+rpt3+deb12u11 ( Debian -- User Support )
Apr 19 19:45:50 zynthian startx[54042]: Current version of pixman: 0.44.0
Apr 19 19:45:50 zynthian startx[54042]: Before reporting problems, check http://wiki.x.org
Apr 19 19:45:50 zynthian startx[54042]: to make sure that you have the latest version.
Apr 19 19:45:50 zynthian startx[54042]: Markers: (–) probed, () from config file, (==) default setting,
Apr 19 19:45:50 zynthian startx[54042]: (++) from command line, (!!) notice, (II) informational,
Apr 19 19:45:50 zynthian startx[54042]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Apr 19 19:45:50 zynthian startx[54042]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Apr 19 19:45:50 2026
Apr 19 19:45:50 zynthian startx[54042]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Apr 19 19:45:50 zynthian startx[54042]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Apr 19 19:45:50 zynthian startx[54051]: ----------------------------------------------
Apr 19 19:45:50 zynthian startx[54051]: Linux Version: bookworm
Apr 19 19:45:50 zynthian startx[54051]: Kernel Version: 6.12.47+rpt-rpi-2712
Apr 19 19:45:50 zynthian startx[54051]: ZynthianOS Version: 2601
Apr 19 19:45:50 zynthian startx[54051]: Virtualization: none
Apr 19 19:45:50 zynthian startx[54051]: Hardware Architecture: aarch64
Apr 19 19:45:50 zynthian startx[54051]: Hardware Model: Raspberry Pi 5 Model B Rev 1.1
Apr 19 19:45:50 zynthian startx[54080]: /zynthian/config/img/fb_zynthian_boot.jpg is a 1920x1280 JPEG image, color space Grayscale, 1 comp, Huffman coding.
Apr 19 19:45:50 zynthian startx[54080]: Zooming image by 100%…done
Apr 19 19:45:50 zynthian startx[54080]: Merging…didn’t find evidence of prior run.
Apr 19 19:45:50 zynthian startx[54080]: done
Apr 19 19:45:50 zynthian startx[54080]: Building XImage…done
Apr 19 19:45:51 zynthian startx[54082]: Loaded libzynaudioplayer using libsndfile-1.2.0
Apr 19 19:45:52 zynthian startx[54082]: Started zynmixer_chan
Apr 19 19:45:52 zynthian startx[54082]: Started zynmixer_bus
Apr 19 19:45:52 zynthian startx[54082]: Started libzynseq
Apr 19 19:45:52 zynthian startx[54082]: Started libzynsmf
Apr 19 19:45:52 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 1, delay: 370.0us
Apr 19 19:45:52 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 2, delay: 1211.0us
Apr 19 19:45:52 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 3, delay: 39208.0us
Apr 19 19:45:52 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 4, delay: 40388.0us
Apr 19 19:46:18 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 5, delay: 2945.0us
Apr 19 19:46:18 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 6, delay: 100018.0us
Apr 19 19:46:18 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 7, delay: 100018.0us
Apr 19 19:46:18 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 8, delay: 100018.0us
Apr 19 19:46:18 zynthian startx[54082]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 9, delay: 100018.0us
