@wyleu firefox, chromium and chrome to be sure. But with all of them it worked beforehand.
@jofemodo , tried all this, cleaned any caches, tried direct address… but no access.
Short version: If I “burn” the older image 2024-03-01-zynthianos-bookworm-aarch64-oram-2403.img on SD card, the VNC server is accessible and the entry in the dashboard’s submenu.
If I use the newer 2024-05-22-zynthianos-bookworm-aarch64-oram-2405.img, it is not!
Longer version:
I am momentarily burning the SD card the 3rd time (2024-05-22-zynthianos-bookworm-aarch64-oram-2405.img) and starting from scratch. This time I’m using LAN not WiFi.
I restarted the router, the desktop and zynthian.
Set VNC to ON, it shows “ON” on the dashboard page of webconf, but no entry in webconf menu.
While logged into zynthian:
ps xau | grep vnc
results in …
root 1676 0.0 0.3 19040 11796 ? Ss 19:34 0:00 /usr/bin/perl /usr/bin/vncserver -localhost no -rfbauth /root/.vnc/passwd :1
root 1677 0.0 2.0 241232 77904 ? Ss 19:34 0:00 /usr/bin/Xtigervnc :1 -localhost=0 -desktop zynthian:1 (root) -rfbport 5901 -PasswordFile /tmp/tigervnc._ifQlk/passwd -SecurityTypes VncAuth,TLSVnc -auth /root/.Xauthority -geometry 1920x1200 -depth 24
root 1678 0.0 0.0 2320 1280 ? Ss 19:34 0:00 /bin/sh /etc/X11/Xtigervnc-session
root 1684 0.0 0.1 7876 3968 ? S 19:34 0:00 tigervncconfig -iconic
root 2154 0.0 0.1 29660 6080 ? Ss 19:34 0:00 /usr/bin/x11vnc -forever -bg -rfbport 5900 --rfbauth /root/.vnc/passwd -shared -o /var/log/x11vnc.log
Now I was installing the older image (2024-03-01-zynthianos-bookworm-aarch64-oram-2403.img):
Same process, but this time, when I was switching VNC to “ON” the sub menu entry appears in the dashboard view of zynthian’s webconf.
Logging into zynthian and …
ps xau | grep vnc
results in …
root 1780 0.0 0.1 29492 5824 ? Ss 20:11 0:00 /usr/bin/x11vnc -forever -bg -rfbport 5900 --rfbauth /root/.vnc/passwd -shared -o /var/log/x11vnc.log
root 1781 0.0 0.0 6932 3244 ? Ss 20:11 0:00 bash /zynthian/zynthian-sw/noVNC/utils/novnc_proxy --vnc localhost:5900 --listen 6080
root 1803 0.0 0.3 19020 11864 ? Ss 20:11 0:00 /usr/bin/perl /usr/bin/vncserver -localhost no -rfbauth /root/.vnc/passwd :1
root 1804 0.2 1.9 241324 77520 ? Ss 20:11 0:00 /usr/bin/Xtigervnc :1 -localhost=0 -desktop zynthian:1 (root) -rfbport 5901 -PasswordFile /tmp/tigervnc.24TW03/passwd -SecurityTypes VncAuth,TLSVnc -auth /root/.Xauthority -geometry 1920x1200 -depth 24
root 1805 0.0 0.0 2320 820 ? Ss 20:11 0:00 /bin/sh /etc/X11/Xtigervnc-session
root 1811 0.0 0.1 7876 4000 ? S 20:11 0:00 tigervncconfig -iconic
root 1955 0.0 0.0 6932 3236 ? Ss 20:11 0:00 bash /zynthian/zynthian-sw/noVNC/utils/novnc_proxy --vnc localhost:5901 --listen 6081
root 2347 0.0 0.0 6092 1920 pts/0 S+ 20:13 0:00 grep vnc
see the two extra lines of novnc_proxy calls??
Obviously with the newer image, freshly used, the novnc_proxy script is not called, I check it later when going back to the newer image download again.
Now I am upgrading to see the difference.
I’ll write another post on the result of the update process.
