IMPORTANT NOTE FOR ALL ZYNTHIANERS!! Please, don’t leave the VNCServer enabled by default. If you do so, you are calling for problems. Plugin’s native GUIs are not well tested on zynthian and for sure, more than one will cause performance problems and crashes. Only enable the VNC Server when needed, and disable it when you don’t need it.
I’m seriously considering to disabled the persistence of VNC Server, so you have to explicitly enable it on every boot…
If VNC server is disabled at startup then after enabling you may have to reload the snapshot so that the engines restart with their GUI because when there is no display server available engines will start headless. It is possible that disabling the option may stop some engines working properly also necessitating a restart.
Should (relevant) engines be restarted when this option is toggled?
After a new Balena Etch of the last working image,
and updating from the Zynthian,
then updating from zynthian.local,
further installing TigerVNC-scraping-server:
Dexed does not output sound when admin VNC Server is enabled.
Solution:
Disable VNC Server when it is not needed @jofemodo
Remove all Layers and re-load Dexed when VNC Server is disabled.
