Way to pause midi playback using midi recorder
I’m enjoying using my zynthian to record midi. I use the midi recorder to capture short sequences, and then I play those midi files back using the midi player (the screen says midi recorder at the top).
Is there a way to pause playback of the midi files? When I press the triangle button, the midi file stops, and when I press the triangle again, the midi file starts playing from the beginning of the file. I was hoping I could resume playback of the midi file rather than the file starting back at the beginning, but can’t figure out how to do.
Pause is not implemented. Please add a feature request to issue tracker.
Thanks. I added feature request.
