Nice! But… If you change and save in webconf then change and save again (before reboot) the machine reboots when you click save the second time. This is unexpected (and inconsistent) behaviour. A small niggle but annoying.
[Edit] Also it would be nice to keep the comment in the config file above the cpu speed settings.
Hi jofemodo,
I would like to be able to use the testing branch but I still cannot build zyncoder because of undefined zynswitches. If you could please take a look at issue #597 again it would be greatly appreciated. I see these new options after testing update (of course UI won’t start) but when I try to save any changes to HW config I receive server internal error 500. I was trying to see if I could change kits to get UI back up and then change back to custom kit but no luck even changing kits now.
Sorry not sure if their related so I posted here.
I changed to testing to try the overclocking feature. But currently the (VNC) UI directly starts in Audio Mixer and i can’t figure out a way to leave that screen.
Bold press layer button to show menu. Short press Select button to enter selected chain. Bold press Select button for the chain context menu. The navigation was written down somewhere but is a WIP so not finalised our fully documented yet.
