When loading the snapshot screen inside webconf the page is not fully visible.
Probably it is something with browser setting.
The same with Chrome and Edge.
By reload you see the right part only milliseconds.
I am not seeing this behaviour. What browser on what OS and what version of webconf are you running?
I have the same issue on Chrome.
I raised this a week ago:
When you add a new directory the snapshots become visible until you refresh the screen.
Gonzo
Sorry, i can’t reproducce the issue. Could you send the output of this command:
tree /zynthian/zynthian-my-data/snapshots
This was a problem in the Pre-staging version. I raised the issue then too.
I renamed my Favourites directory to 001-Favourites. No change to the behaviour.
Here’s my tree
Gonzo
Sorry @gonzoB !
I can’t reproduce your problem. Really! And i tried creating snapshots with the exact names you used, Chrome & Firefox, but nothing. I suspect you are missing something in your description of how to trigger the bug…
How do you copy/restore the snapshots?
Can you reproduce the problem when starting from scratch with a fresh SD image and NOT copying any snapshot but creating new ones?
Update:
Thanks,
Gonzo
Further update:
Conclusion: There’s a program problem in the web screen.
Gonzo
Further further update:
I flashed a new image from stable, then ran the program update.
Then I looked at the snapshots screen (with no snapshots). The 000 directory is not visible. It’s there, just not visible.
Gonzo
OK! Now i can reproduce the issue
I just pushed a workaround to testing. Please, switch to testing and test.
Yes, that works.
Gonzo
Nice! It’s on stable now
