Hi @Zynthianers !
The webconf tool has been updated. Big Thanks to Markus Heidt (@mheidt ) who is working hard to improve the tool.
New => The tool is getting bigger, so we have organized the menu in 2 levels.
Fixed => “Reboot” option
New => Audio Mixer Master volume
Improved => WIFI config
Some features are not implemented in the “core” yet. You can configure it, but not use it
Library => Snapshots
MIDI configuration => Master MIDI channel, etc.
The full list of fixes and improvements is long, but you can check the changelog in github:
lod
July 15, 2017, 9:42pm
2
Hello @jofemodo and @mheidt !
This are great news. I realy like the webconf!
Martin
Hi guys!
After the update i’m getting the following error:
Any tips?
Regards, Rod.
mheidt
July 16, 2017, 9:24pm
4
Hi Rod,
I can’t test the latest master branch for the next 3 weeks.
But if you would stop the service and run the webconf shell manually, you would see the log message.
Maybe there is a workaround until I checked it myself.
Kind regards
Markus
mheidt
July 17, 2017, 8:53am
5
Rod, which soundcard are you using?
Could you post the results of
amixer scontrols
Sorry for the delay, Markus.
This month i will be on business trips all the time. As soon as i can call my Zynthian home i’ll send more details.
I’m using an AudioInjector.
Regards, Rod.
Hi @mheidt
I started webconfig manually and only had the following error:
amixer: Mixer attach default error: No such file or directory
But, after setting up zynthian and rebooting, it worked fine!
Regards, Rod
mheidt
July 22, 2017, 5:34pm
8
You don’t get the 500 either?
mheidt
July 22, 2017, 5:36pm
9
And please check how many volume sliders you have. We can filter them when we know which.
I fixed the problem 2 days ago, but i forgot to notify:
committed 12:40AM - 22 Jul 17 UTC
Hi ynthianers!
I’m having a little problem with the ALSAMixer settings with Webconf.
Every time I change some ASLAMixer parameter through Webconfig and restart Zynthian, the option “Output Mixer Line Bypess” returns on.
Is it possible to enable this option in Webconfig?
PS.: I’m using an AudioInjector Souncard
Regards, Rod
mheidt
October 16, 2017, 6:48am
12
Actually I provided a mechanism that allows to disable unused controls.
Especially those boolean ones.
i can offer that only “Master” and “Capture” is shown in the webconf.
Would that help?
That’s how i did it with the soundcards I know.
Hi @rod_amaral !
Normally AlsaMixer saves the changes you make and restore it at startup.
Can you verify that this save/restore feature is working for other controls?
Hi Guys!
I’m on a work trip this week, I’ll check the settings as soon as possible!
Regards, Rod
