Hi, I’m still trying to fathom out the system for loading and saving snapshots and I don’t seem to be able to save a snapshot (or rename it ?).
I’ve just run the zyncoder_test program and it has shown the following switch assignments:-
CH - switch 2
LS - switch 0
Back - switch 1
Select - switch 3
or on starting Zynthian
SETUP GPIO SWITCH 0 => 107
SETUP GPIO SWITCH 1 => 23
SETUP GPIO SWITCH 2 => 106
SETUP GPIO SWITCH 3 => 2
Is this correct?
The process I am trying to create a snapshot from fresh boot is as follows:-
Select ‘New’ - snapshot 1 with ‘Select’ button
Select LinuxSampler engine with ‘Select’ button
Select Channel 1 with ‘Select’ button
Select SFZ/DSK-Grand Piano with ‘Select’ button
Select Classic Grand Piano Bright with ‘Select’ button
- patch is now loaded
Long press LS button - Channel 1 shows SFZ/DSK - Grand Piano/Classic …
Press LS button - Display goes back to Engine selection
What am I doing wrong?
